MrHorsepower
![434069154_18420388780017939_3394940503735111599_n.jpg](https://scontent.fadl6-1.fna.fbcdn.net/v/t39.30808-6/434069154_18420388780017939_3394940503735111599_n.jpg?_nc_cat=100&ccb=1-7&_nc_sid=5f2048&_nc_ohc=zp6K4yJ7AgoAX_q7dkB&_nc_ht=scontent.fadl6-1.fna&oh=00_AfA9g9ImKWNATs-jiIVIe45yDkGmfYVgqGmjx-V0aanPHQ&oe=66009826)
Just popped up on the ATW Facebook page ????
Just looked up the solar panels, are you planning to stick them straight onto the roof?
Complete Campsite used to glue that type of panel to the roof of the Exodus range.
They stopped using them due to failure rate over long term plus performance dropping dramatically on hot days due to the lack of air flow and getting to hot
They have now gone back to solid panels mounted with a gap under them which also keeps the van a lot cooler inside
If you’re going down the diesel heater path why not incorporate the hot water with that?
We have a diesel water heater and ducted heating in the van, uses stuff all fuel, small and compact, heats the van and water at the same time if you need both which you often do when the better half showers and heats water o full temperature in about 10 minutes
They sell a kit where they sit 10mm off the mounting surface for airflow to maintain performance, yes you are right that a lot of those panels fail from uv exposure but this particular brand has got a patented version and are the only ones approved by the clean energy council and get used in commercial applications on trains, boats etc.
They are expensive by comparison but I like the slim profile and more important the weight savings as I am having a pop top . Don’t know how I would go with normal panels on a riof 2.2x4.5 long lifting it without fitting actuators which I was hoping to avoid the added complications
Couple of comments for what they are worth.
Combi diesel heaters work well. Their space heating is not as hot as a stand alone space heater but is adequate for Australian temps.
If you are thinking of a slide out external kitchen, have you considered its working height. Would probably need to be a drop down design on a truck (or carry a fold up work platform to use it)
Consider plumbing your fresh water tanks separately with change over taps, if you need to fill up remotely with say bore water, you can choose to only fill and use one tank for showering etc and keep the other for just drinking water. And put in twin, 10” water filters after the tanks. And a tempering valve for the shower or a flick mixer shower tap, saves water getting the temps right.
Instead of carrying a back up LPG cooker and bottle/s, consider a butane portable.
When I asked this question of a seller he recommended going higher lpm. The smaller ones are noisier. If you can find something in the higher ranges they tend to be quieter. I can't find which company it was I was taking to... It might have been at a show.Can anyone recommend a water pump? Something that isn’t too noisy
Get an accumulator tank so it doesn't turn on and off all the time.Can anyone recommend a water pump? Something that isn’t too noisy
I had the renology dcdc and it was flawless especially considering the price. Had two mates who have both now used their stuff.I am thinking 600amps of storage capacity will do me fine coupked with a decent solar array and only want middle of the road quality. The reasoning for that is whilst I want them to be reliable I think they can become redundant with technology advances before their end of life so rather be in a position to easily upgrade or in the case of failure just swap them out for what is readily accessible
Ebay has a sale and can pick up 2 x Renogy 300ah for around $1300 each which has me thinking……..thoughts?
Renogy Core 12V 24V 48V 300Ah Lithium Iron Battery 4WD LiFePO4 in Series | eBay
Get the extra capacity to brace for unexpected storms, hurricanes, wildfires, and other challenges whenever you need it. You're just a step away from transforming your fishing boat into a haven of modern comfort.www.ebay.com.au
@Albynsw Saw a massive, but short, Earth Cruiser Unimog in our travels this week. Impressive. It had Sherpa winches front and rear if you are still thinking about winch choices.
