Alien d2
With all the talk of cheaper winchs on the market I thought maybe a discusion about cable dampers would be good to have.
How does this sound?...
When using a steel winch cable a dampner should be used incase of a cable failure.
The idea is to keep the recoiling ends low to the ground to reduce injury to an users.
So some questions to start the descusion....
-How heavy should this damper be?
-I was told if you don't have one you could use a jumper, blanket, coat, any thing to hold the cable down, does this sound right?
-If I use a coat ect. should I add weight to the pockets(rocks?) to keep it low to the ground incase the cable does fail?
-How far along should it be? 1/2 way or 2/3 and from which end(closser to the winch or anchor point)?
-Is lifting the bonnet to protect the driver a good idea?
-Is one per run of cable enough or should we use two?
-Does this apply to nylon rope too?
So whats your thoughs?
Please add anything to the discusion you feel would be good for people to think about.
