Just guessing, but based upon how it works between the Dmax and MUXI'm in the camp of thinking its basically a hilux wagon but I have a couple of questions-
1. the fortuner has a shorter wheelbase. Do they acheive this by cutting the existing chassis down or do they make a completely separate chassis?
2. Why does the fortuner have a 50mm penalty on ground clearance over the hilux?
3. Why can't the fortuner tow as much as a hilux?
When toyota downgraded the fortuner they were adamant the hilux was right at 279mm.I think you will find that they have the same ground clearance, the 279mm quoted for both the Hilux and the Fortuner (later revised) should have read approx 225mm for both.
Yes, without rereading it seems all of this here is hearsay apart from one poster claiming experience but not saying what - which year, what distance, what application.Ziggy, lots of posts on forums is hearsay, and a lot is good solid information. Picking the difference is the tricky bit. That's why I like to check things.
Wrt the Fortuner verses Hilux though, the evidence from lots of posts on lots of forums, plus professional reviews, plus others who work on them, plus wikipedia, plus Toyota's documentation shows they are the same platform on the same production plant. Toyota even have had a IMV platform strategy for the Fortuner and Hilux for 15 years. The evidence from every single source aligns except for one, your mechanic. He might be right but nothing supports what he is saying.
I was just asking if he had something to back it up, otherwise to me it just seems like another random statement on a forum. That's all. And your mechanic isn't the one looking to be out on the edge right now.
I honestly wouldn't be surprised if it was BS by the marketing department to score some points against the ranger. Although the new hilux "rugged" has a listed clearance of 220mm or so which is a bit odd.Yeah I know and I have never measured it however I find it hard to believe that there is a 50mm difference considering tyre size ect, I'll put a tape measure on it when I get a minute.
Did you expect any better?
You haven't said that you've been over at the Fortuner forum. Maybe I'm the only one who has.
The sources you mention are very variable in detail and credibility and few even address long-term performance.
If there's an international model take a look at the JD Power dependability survey.
Locally read the reviews on www.productreview.com.au. A couple of issues get a mention that the Tojo fanboys here haven't heard about.
I think they used the same tape measure that toyo owners use for measuring their appendages.I think you will find that they have the same ground clearance, the 279mm quoted for both the Hilux and the Fortuner (later revised) should have read approx 225mm for both.
Which sources? Journalists reviews? Lol.Yours is hearsay also. Those sources he mentioned are likely a lot more reliable then some mechanic.
Yep, done arguing with Ziggy whose only defence is to attack the person rather than provide any facts. Been there, done that, more than once.
Tink
LOL I think I have wasted enough time on this one....Come on guys we were just getting started.
