smitty_r51
I looked at the fortuner as a possible replacement on the pathfinder... Same car...
The payload on the fortuner was awful
Could you tell us some more about this?That’s no longer an issue with the new prados.
You need to consider the possibility that it's not built the same way as the Hilux. 'Based on' doesn't necessarily mean the same.
Maybe the design brief was more Kluger than 76 seies.
There is a lot of info on pradopoint, from memory I think the prado from 2010 to 12 had the issues with the body cracking In the front wheel arches. There is also the issue of cracked pistons in the 3L engine. Go and check out pradopoint, all the info is there.Could you tell us some more about this?
It was on my short list till I heard about the cracks.
Pretty sure they just made the body in the wheel arches stronger/thicker.Thanks.
I did a search on PP a few months back and found little.
I recently contacted an automotive engineer who specialises in 4WD cracks and when I said I wanted to talk about cracks in my wagon he said 'Got a Prado?'.
So Tojo will have needed to change something in recent models. Any idea what?
https://www.pradopoint.com.au/forum...150-series/18537-150-cracked-inner-guard-listThanks.
Seriously? Do you really think that Toyota are going to change body panel thickness for identical panels on two different models? Or are they going to change assembly or maybe construction methods between models using identical panels? What you are suggesting is not an economical proposition for two almost identical models.You need to consider the possibility that it's not built the same way as the Hilux. 'Based on' doesn't necessarily mean the same.
Sure. The specs are good but how tough is it?
My mechanic, who has a thriving 4WD servicing business, says it's not built like a Hilux.
Lot of people would say the DMax and MU-X are tough but my MU-X like others has developed body cracks.
I appreciate your neighbour isn't looking for Tojo 76 tough. I don't see any Fortuners outback or on rough high country tracks so maybe the news isn't in yet, and at the best of times bad news stories like body cracks don't get a wide press.
So have a few Dmaxs. Mostly due to front end accidents, like yours Ziggy, or the fitment of aftermarket bullbars, also like yours Ziggy.Lot of people would say the DMax and MU-X are tough but my MU-X like others has developed body cracks.
Thanks.
heheh, yeah, they're pretty agricultural.I dunno Ziggy. I wouldn't buy one, but i wouldn't buy a Hilux either.
70 series. I nearly got a dual cab, but after driving in my mates Troopie for 500 km on the Connie Sue, I was glad to rest my ass in my 200 soft roader for the next 3000kms
Thanks. Not looking at a 2nd battery up front but that's good to know.I think you will find these cracks are all related to ones fitted with duel batteries and a lot with poor trays / poor installation that see corrugated off-road use.
Use a good tray, limit battery size / weight to manufactures specs, ensure the battery is fastened down and cross braced
Piranha off road use a decent size battery but the top is cross braced to stop them rattling around
https://farm1.staticflickr.com/684/31829885693_2088d0f4dd.jpg
And what's your evidence for that?
Exactly. As I said earlier, unless your mechanic is also an automotive design engineer, then his opinion is useless.I'm not quite sure to be honest why your mechanic would say they are not built as well, perhaps he just has no idea.
