John U
3 leg design might be deliberate. 3 legs will sit flat, without rocking, on any kind of surface. 4 legs needs a flat surface or varying leg lengths to prevent rocking.Tried out the little stove for the last couple of morning coffees and it worked a treat. The wind guards can fold up close to the coffee pot to contain the heat and it brings it to the boil faster than the conventional butane stoves.
The only negative I would say is it only has a three leg trifet and there is a good chance you could tip a pot or pan off it when in use but perfect for the coffee pot. There is another similar model that has a larger 4 leg trifet which I have ordered to see what it is like, it doesn’t have the wind guard though which is why I didn’t get it first up.
All of this for a product I don’t even need in the first place hahaha
Not sure if you already knew this. Did not find this out until digging very deep into buying a bike work stand and ending up with a couple that were only any good in the garage.
If you've got a flat table top, no dramas.
