cnut
Ok, so I got the 50mm lift I needed on the back end, now the challenge is to get the same on the front.
Big problem with independent / torsion bar front ends is that when you jack the torsion bars, you may get the lift you want, but you sacrifice the available down or extension travel and that's not good. For example, the Standard Jackaroo has about 60mm of extension travel on the front wheels so if you jack up the torsion bars to give a 50mm lift, then you're left with a miserable 10mm of extension travel and that does nothing for traction when you're off road.
I read about the "ball joint flip" and how that improves the situation. Then after a bit more research, I came across a complete solution to the problem. Today, I installed that solution in my Jackaroo and the results were awesome. I now have a 50mm lift on the front end and still have 60mm of extension travel
Matt at www.independent4x.com was a huge help, they make mods for all sorts of 4wd's but since they are in the good ol US of A, I felt a bit uneasy about just placing an order and keeping my fingers crossed so I emailed for some more information. I got prompt and informative replies from Matt, he was able to answer all my questions and recommend an appropriate solution the price was pretty good too
Anyway, here's half of what I got (two sets in the kit)
Installation was simple and I was able to complete the whole job in about an hour.
Stage one - release the upper ball joint from the knuckle. Notice how the ball joint is bolted to the top of the upper control arm. You have the most room at this stage to do the droop stop, so just pull the old one out and replace it with the low profile stop from the kit. You can see mine is already installed in this photo. (The shiny bolt sticking up through the control arm)
Stage two - unbolt the upper ball joint, remove it from the control arm and reinstall it in the knuckle. Then place the spacer on top of that.
Stage three - using a jack, lift the whole assembly up and using the high tensile bolts that came with the kit, bolt the ball joint and space back to the underside of the control arm
That's all there is too it, just repeat on the other side, throw some wheels back on, drop her back on the ground and adjust the torsion bars to achieve the desired amount of lift.
If you don't go the full 50mm of lift, you will have even more extension travel than me, but I'm really happy with mine and highly recommend the service and solution I received from www.independent4x.com
I got another upgrade from them also, but I'll cover that in another post.
Craig
Sent from my iPhone using Tapatalk - now Free
Craig
