Hi Guys, I’m from FYRLYT Pty Ltd and I have some info re the correct fitting of ancillary electrical equipment (EG: spotlights etc) to the new 2013 Ford Ranger with the ECU controlled modulated voltage alternator output.
This came about because a customer rang us and said a 4X4 shop had told him he could not fit FYRLYT 150 watters to his new Ford Ranger because the new charging system would fail with the current draw of the halogens. However he did offer to sell him some much more expensive HIDs that apparently would not cause a problem with the Ford Ranger charging system.
As I knew little (NIL) about this system I visited “Stillwell Ford” of Medindie and told them the situation. I had all my test equipment with me so the service manager (Peter) offered the help of the mechanic /electrician whom had done the latest course at Ford head office on the new charging system.
He informed me the new charge system uses a coil sensor that senses all current draw (amps) that are being drawn through the NEG earth cable and signals the ECU to raise or lower the output of the alternator to keep the voltage at approx 14.2 volts when under load, to as low as 12.6 volts when under virtually no load. EG: engine running, batteries fully charged and no lights or accessories on (fridge etc) or under hard acceleration.
This sensor is attached to the NEG battery cable right next to the clamp that attaches the earth cable to the battery negative post. It is black and approx 20mm x 30mm
It is absolutely imperative that all ancillary equipment that is added to the vehicle has the negative wire of the accessory bolted to the body end of the battery earth cable (downstream of the ECU sensor) or vehicle chassis and NOT to the negative battery post.
This will allow the ECU to recognise that there is a higher load required and will change the output current accordingly. However, if fitted to the NEG terminal the ECU will have no idea that you have applied an extra load to the system. The electrician at Stillwell Ford informed me this was the most common failure of people fitting their own accessories without knowing the requirements of this system.
The positive wire of your accessory can still go direct to the Positive post of the battery as normal.
We did load and voltage output tests in the workshop on a current model 2013 FORD RANGER. This vehicle had dual batteries with a ”Pirahna” charge module, electric winch and two 100watt halogen spotlights fitted.
With the assistance of the Ford electrician we did the following tests. All with engine at idle.
Battery voltage / engine OFF = 12.86 volts
Start engine @ 5 seconds = 14.50 volts
@ 1 minute 20 seconds = 13.20 volts
@ 2 minutes 30 seconds = 13.61 volts
@ 3 minutes = 13.80 volts
@ 4 minutes = 14.00 volts
@ 6 minutes = 14.45 volts
Voltage stabilised
14 minutes = 14.45 volts
Switched on low beam headlights and tail lights. Volts dropped to 14.38 volts for 1.5 seconds while the ECU recognised the load then returned to 14.41 volts. Approx 180 watts draw / 12.5 amps.
Then switched on high beam plus 2 x 100 watt halogen driving lights. Volts dropped to 13.80 volts for 1.5 seconds then returned to 14.30 volts. Approx 510 watts draw / 35 amps.
Then added 2 x 150 watt FYRLYTs to the above load. Volts dropped to 13.80 volts for 1.5 seconds then returned to 14.30 volts. Approx a total of 810 watts / 56.6 amps.
All at idle RPM, quite impressive I thought.
So we can see from this that it is a very good system that responds within 1.5 seconds to any change in demand. This vehicle comes with a 140 amp alternator so it can easily handle several of these lights if required.
So the moral of this story is make sure you attach your negative wire downstream of the ECU amp sensor and don’t believe everything a sale guy tells you as he may just be trying to sell you product where he makes more profit. So do your homework.
Hope this is of some help to somebody with a Ford Ranger or vehicle with a similar charge system.
I would also like to thank Stillwell Ford for their assistance in this test.
Voltage stabilised
