Hi readers, I found a quick easy fix to lighten the steering on the 200 series, I found it on another forum some time ago and it works, there is an adjusting screw on the outlet pipe on the power steering pump and I backed it off two full turns, ( ACW ) and this lightened the steering considerably. I was getting sore hands after a few hours behind the wheel and now it’s like power steering should be. I do not know if this is a recommended fix or if it may cause later problems so proceed at your own risk. All I can say so far is it’s so much better to drive.
