Where did you run your oil return to?
How much boost are you running?
What did you clean the intercooler with?
Ben
Hi Ben,
10PSI. Cooler was added after i installed the provent purely cause i didn't want any muck. Return line i'm running half meter hose with a bolt & clamp. Empty it first time on the weekend got about 30MM of oil so its def doing its job.
Intakes are clean and rubber hose around cooler pipes are clean
My TD 100 series needs one, the intercooler pipe joints all weep oil just from the blowby. I would rather collect the oil than burn it.
Nice job on the install, was it one from ebay? how much did you pay for it?
I would like a site tube to monitor the oil level inside.
a bit like this
Square Oil Catch Can | eBay
