On startup notice that the dual battery volt gauge dropping right down on the main battery on startup -- Drop into my local battery guy and had both my main and auxiliary battery testing.. Yep the main starter batter was very week and failed the load test.
Well that is only 2 years for the main battery, the I live in Darwin the tropics -- it stuffs batteries-- I was really surprised that the auxiliary battery completely passed the tests, as the auxiliary battery has had plenty of use with the fridge, my guess being in the canopy it's cooler for the battery.
I have now replaced the main battery with a $380 Optima dual purpose marine battery, that they call a blue top
Nice figures, but I guess it should be at $380 --- should be good for my winch.
Living in Darwin and the wet season, not getting our 4WDing at this moment, it's been a good time to fix the lighting and the electrical system in my canopy.
First up I built a electrical cabinet, I made the cabinet out of a tool/part organiser similar to
SCA Tool Organiser - 8 Compartment, it was sitting in my shed and it was just the right size, so after a few mods with a hole say, and mounting it on a piece of marine ply..
Note the marine switch panel that I mounted in the lid -- From Jaycar
Marine Switch Panels with Circuit Breakers - Jaycar Electronics for $28
I wanted, everything to use circuit breakers, and no fuses, and with 16-Way 100A Brass Distribution Bars, to make it easy to add the wiring, and extra cabling later. The 16-Way 100A Brass Distribution Bars came from Jaycar
16-Way 100A Brass Distribution Bar - Jaycar Electronics
I have used a 70AMP Circuit breaker/Isolator switch for the main feed into the cabinet/box that I purchased from a boat shop.
Used plenty of Anderson Plugs around the canopy
I use the Anderson plugs for my fridge, for plugging my air compressor and for pluging in my solar panels. -- The best place I find to purchase Anderson plugs is from Ebay -- I paid about $18 for 10 plugs -- To purchase Anderson plugs from Jaycar they are about $12 each -- it's the same plug.
As for running the fridge from the Anderson plug, I have modified the Waeco lead to include a 10A blade fuse
For lighting I have mounted the lights on the gull wing doors on the canopy
Those light are 12V work lights that I purchased from Bunnies at about $8.50 each, and they certainly throw good light.
The work light -- with shielding extra they look nice and neat.
A 600W pure sinewave inverter that I purchased off ebay for $78 delevered
Tested with a 750W drill, worked fine, Then tested it with a industrial pedestal fan -- yeah I was amazed with the industrial -- this was only a test, all I am planing on doing with the Inverter is powering/charging laptops, powering low wattage 240V lighting, and running small 40W box fans.
