I worked in the USA for almost seven years. Part of my time here was spent as an engineering instructor with BP Oil at one of the main refineries. One morning I noticed that the tradies were liberally applying Anti Sieze to the threads of the ammonia compresser head bolts. These were about 38mm in dia. and about 3m long. The last thing you ever need with this machine is to have the bolts snap when it's running. I very carefully quized the engineer and tradies involved and then sent an e-mail to two of the major bolt manufactures in the US. I asked them about using AntiSieze on the threads of such highly stressed bolts. I already knew what their answer would be, (us Aussies are not dumb!). I had heard some time earlier back home (in Aus) that blokes were snapping their wheel lugs off when simply driving along the road in their 4x4. The problem was in the use of Anti sieze on the studs and nuts for the wheels. The following is the reply from one of the bolt manufactures. The second reply has been lost in transit back home and computer breakdown.
The reply -----
Date: 11/9/99 10:22:53 PM Eastern Standard TimeFrom: Wedgetail1
RE: Anti-seize on boltsDate: 11/4/99 10:14:29 AM Eastern Standard Time
To: Wedgetail
Joe,
When you have a bolted joint you put a specified load on the bolt,
say 96000 pounds load. Then you take same bolt and apply a lubricant to
it, on the threads and the nut face (very important) and apply the same load
the torque can be as little as 1/5 the dry torque value. If you like I can
send you a sheet comparing the two conditions. One dry and one with our 503
lubricant which has a coef of .067 (very slick). If you load the bolt to
35-50% of yield and then use a lubricant yes you can and will over stress
the bolt and probably reach a failure. We at Sweeney have developed a
program that calculates what the torque will be using different lubricants.
If you want to call me and discuss this further please do. 1-888-792-5962
ext 6024. If you would like hard copies of a sample that's ok to, please
send me your fax number.
Your sample below would be as follows:
A .75-10 UNC stud and nut lubricated with oil on the threads and the nut
face torqued to 100 lbs. ft would apply a load of 8,180.881 pounds to the
joint.
A .75-10 UNC stud and nut that has been cleaned and has no lubricant at all,
with 8,180.881 lbs. load applied would take 248.6 lbs. ft.
A .75-16 UNF stud and nut lubricated with oil on the threads and the nut
face with the load of 8,180.881 pounds applied would take only 97.4 lbs. ft
of torque. (Not much real difference)
Now to show the effects of a good quality lubricant:
The same .75-10 UNC nut lubricated with Sweeney 503 lubricant to the threads
only would produce 8,180.881 lbs. load at 77.6 lbs. ft.
A .75-10 UNC nut lubricated with Sweeney 503 lubricant to the head of the
nut only would produce the 8,180.881 lbs. load at 73.05 lbs. ft
Now lets put the lubricant on both threads and nut face.
A .75-10 nut lubricated with Sweeney 503 lubricant to the head of the nut
and to the threads also would produce the 8,180.881 lbs. load at 50.7 lbs.
ft.
As you can see lubricant make all the difference in the world.
248.6/50.7=4.9 time the torque
Sincerely
Bill
Applications Specialist
Sent: Thursday, November 04, 1999 6:39 AM
To:
Subject: FW: Anti-sieze on bolts
The reason the studs were snapping on the 4x4's was that the studs were over-tightened by at least a factor of 5 from simply using Anti-Sieze on the threads and nuts and this put the studs at their maximum load just below the yield point. When the wheel hit a bump in the road, the shock load took the stud (or studs) above their ultimate strength and they snapped. The shear strength of a bolt is half that of the same bolt in tension.
If you tighten your nuts up with an air powered gun or torque wrench after applying Anti-Sieze, you can and will, stress the studs beyond their yield point. The result is broken studs, lost wheel/s and possible injury to all concerned.
Hope this helps you to understand the danger of using Anti-Sieze.
Kody
The reply -----
To: Wedgetail
Joe,
joint.
ft.
Sincerely
Bill
To:
Kody
