devo73
Banned
Gday All
Just a heads up for owners of these vehicles with the new generation 5 cylinder diesel. Models UP0YF1-
Reports indicate there may be an issue with the variable flow oil pump fitted to these engines.
If engine oil is left to drain for longer than 10 minutes the oil pump may fail to prime and leave the engine in a critical no lubrication situation. Attempts to prime the pump by increasing engine rpm fails to solve the problem and will lead to component failure from lack of lubrication.
