won't start with nose facing up hill
Dman
It seems that my 2001 GU Patrol wont start when the nose is facing up hill, I have to prime it again, its like the fuel runs back through the lines and no pressure in the tank, checked for cracks and leaks but nothing,
and suggestions anyone???
goldrush
Had that problem a few years ago. Check all your fuel lines to the pump.One of the supply lines to the pump is probably loose or split.
Split pin
ok Is the motor 2.8 , 3.0 or 4.2 diesel motor. 3.0 litre motor has one way valve at the injector pump. 2.8 and 4.2 have a one way valve on the filter head. some times these valves get a tiny bit of debris stuck in the valve allowing the fuel to drain from the filter.
OzdaddyO
Mine plays up sometimes as well, I'm seriously looking at fitting an electronic fuel pump pre-primer.
MatOZ
First check basics like loose hose clamps, soft hand primer or diesel leaks.
2001 Patrols with ZD30 or TD42 engines have a valve in the filter head which can get stuck open with debris.
Also check the ball valve on the side of the pump isn't stuck open as this causes low transfer pressure in the pump. From memory its 19mm.
Another thing, look at the 2 orings on the bottom of the fuel filter sensor. Seen heaps that oring has gone hard over time allowing air to get in, which gets worse when the vehicle is facing up hill due to gravity. Some people don't bother changing them during service when they drain the filter or don't know they are there.
Also seen a loose injector return line that would allow air into the pump. This hose connects to the pump return banjo fitting with the ball valve. Air gets in here because the valve actually has a small hole drilled on the pump side of the ball.
See how you go
Split pin
See how you go
Exactly mat I couldn't have described it better.:):):)
