Hi everyone,
previously I mentioned about doing my own engine swap (3L eco diesel) in my GC. The time has come with the weather warming up to get everything ready so that once I start it will happen quickly. 1st question I have is about the flexplate bolts, if they are torque to yield or reusable? I want to do the rear main before I put the motor back and check the tone wheel condition and maybe replace it regardless. Also in this regard if the bolts need to be replaced where is the best place to buy, I have looked at Rockauto and didn't see the bolts listed but I have not gone through all the listed parts yet. Similarly, the various coolant hoses I want to replace with silicon and the Aluminium parts too, I know GDL has the set but at about $1k seems a bit dear for what they are. I did see on RockAuto that Dorman make/sell the braided Turbo coolant line for AU$74 ( plus GST and additional postage with other parts) and I have seen on Ebay ranging from $45- 170+. I assume Dorman would be a known quality ( I have bought parts supplied by them in the past for my 92 F150), has anyone bought the Ebay cheaper ones and again I assume they are all coming from a few Chinese factories? I'll probably buy all the various seals from RockAuto but I am going to try and source Viton "O" rings for the coolant pipes from a Bearing supplier as I see it a total waste of time replacing with Nitrile that is going to fail again. So if someone else has already sourced the Viton "O" rings the part numbers would be appreciated. Thanks in anticipation
