Hi all,
I've just pulled the old starter out of the ol' girl and slapped a new Hitachi back in and it was only when I got to wiring it back up that I became unsure about things. On the old starter, the low voltage wire from the ignition went into a plug and was then soldered to a separate tab on the starter solenoid. On the new starter, the only 'tab' I can see comes off of a washer which is on the threaded positive connection from the battery. There is however another smaller threaded connection on the starter solenoid (in addition to the + battery connection and the wire to the starter motor, so 3 threaded connections in total). I'm guessing this is where it goes?
Can I do any damage by hooking it up wrong the first time or will it just not work?
