Winch with factory alloy bar?
Matty G
I have a 2000 GXL 105 series cruiser (with airbags), fitted with a factory alloy bar, which I believe is called an “estate” bar (but happy to stand corrected). Code on bar is TMCA PZQ29 60070 (tried uploading photo but failed...seems to be no winch cutout or markup for cutout).
I’ve heard that a winch can be fitted with a winch cradle the bar, with a hole cut into the bar to attach the fairlead. Saw one fitted up very neatly on the weekend, but didn’t get a good enough look to tell if it was a 100 or 105.
I’m wondering if anyone knows if fitting a winch to my bar possible?
Is it legal (eg: will it affect airbag compliance)?
Will only certain winches fit?
Is this only possible with a winch compatable “estate” bar, and was such a bar made for the 105 (I know there’s one for the 100).
If u get a winch cradel that bolts directly to the frame its alright but.i woild still rather a winch bar. They are more sturdy and when winching under load they will take the strain.
I work for toyota and i have seen first hand the quallity of the alloy bars and i personally wouldnt.
Sent from the nearest track using tapatalk 2
Campin40
Matty G , I've got a 105 cruiser as well. It's fitted with the factory toyota alloy bar and I was thinking the same as you. But really I've realized that the only thing the factory bar is good for is to hold up some spot lights and an aerial. Steal winch bars are expensive but in the long run they are the best option. Ill wait till i can afford one rather than muck around with the alloy bar. The alloy factory bars are about tuff as block of butter.
Waz.
eric162
Definitely go a steel bar preferably a proper winch bar for added safety.
I even took my genuine Toyota steel bar off and replaced it with a purpose built bar.
Look at finding a second hand winch bar or look at getting one made. Will be a quater if the price.
