Has any one had anything to do with a solid state solenoid that are replacements for the four solenoids that most winches come with.
Thinking of changing mine, which is a warn winch pack.
I haven't installed to a winch but in equipment I worked on, the SSR (solid state relays) are great. People that have installed them have like them and no issues with water getting inside of them.
The only problem would be with the slight volt drop across it. Depending on whether it is a triac or SCR you could be looking at up to 0.7 volts dropped. On 3 phase mains equipment the volt drop is negligable but on a 12 volt system it is substantial especially if your battery isn't fully chargd or you have some dirty connections or bad earth to drop more voltage.
They sound like a good idea for me after my winch needed a solenoid replacing (after two uses) under warranty.. I think Hobzzee on Ebay and Avenger (who sell the Tiger winch) do one.
