Winch Question
G'day All,
I have just got hold of a winch from my brother and he's stuffed the cable
Just wondering wether to go for rope or cable
its a 9000 pounder and only been used twice. Ive had a look on ebay at the prices of rope and its fairly steep and Im on a budget of not much.
is it really worth geting the rope over cable i know its stronger and lighter but for the price i'm thinking just sticking with cable.
any thoughts would be good thanks
the rope price i found was 8mm 13 bucks a meter or buy 30M for $405
compared to cable bout $100.
Cheers Cam
bmurray2250
If money is tight, cable is the best option. Cable also tougher in dirt/rocky/mud conditions. Rope if it rubs on rocks will weaken.
Grumpy
Cam I would stick with the cable and ask around someone might be able to make you a new cable a little cheaper but I would have considered that price pretty reasonable.
croozza
Cable all the way Cam, synthetic rope needs cleaning after every use to make it last longer, also it does not like heat, so if the winch was not designed for synthetic cable you should only use steel. Also remember to run the winch all the way out and then back in again fortnightly, as this will ensure that it is in good working order for when you do need it, as it will keep all parts lubed.
Cheers guys I have now got a cable swung past a forby shop and they had just done a rope conversion and the cable is in perfect condition he was going to chuck it out lol scored well I rekon.
Another question if anyone can answer is the winch I have got is an ironman 9000lb and I rang up
Burson who supplie them and they rang Ironman as Im chasing some parts they don;t make parts for them wich is bull@#$t they rekon they never sold spares. Is there any other brand around who sells parts which will fit??? I saw in latest 4wd action mag they service a winch and it looks the same but its a Tmax. any help would be good cheers Cam
croozza
what parts are you after, as some will fit while others will not.
Need new magnets
and brush springs or the whole top carrier with brushes and springs the Tmax look the same in a magazine I got thats about it armature is still good and the plates that go between the magnets are good so yeah only after magnets and to assembly as the wires would be fairly restrictive on the current as they all black and look fragile.and britle
croozza
Need new magnets
An auto electrician should have the parts
Do you know who sells them because the motor looks exactly the same as the ironman winch and if they sell parts might be able to match them up or last case go to auto elec
Do you know how to make the Pic for your profile to show up i uploaded one this morning and its in my profile it rekons but i cant see it when i go through the forum
Mongrel Lux
G'day cameronpatrol, Tmax is the TJM winch, but I don't know where it's made or who makes it. Acording to 4wd Action mag comparison test, PREMIER was the best value for money winch. Generaly, STAY AWAY FROM IRONMAN I've never heard anything nice about them. But if money's tight, & make do with what you've got.
When you get the Ironman winch fixed & working well, SELL IT & put the money towards a GOOD cheap winch. Ask about spare parts availability when looking for your next winch. Some that I've heard ( from people who own them ) that are well worth a look at are: the T I G E R 2, a mate of mine bought one on e-BAY for $ 400 that's about 1/4 of the price of a Warn. PREMIER & also the T MAX ( TJM ) is also good value for money. ALSO MAKE SURE it is well sealed. Some winches DON'T LIKE GETTING WET, so they're no good for river crossings or bog holes. Where you're most likely to need a winch in the 1st place.
Hope this helps
Mal
Mongrel Lux
For me, I wanted the lowest current draw I could get , the longest Duty Cycle i could get & the most water tight winch I could get. So I went for the WARN XD 9000 ( 4.2 h/p motor ). But then again I only looked at Warn Winches.
Also, long before I bought the winch I new I was going to get one, so I got an Exide Orbital 1,000 CCA battery. Like the Optima but a bit cheeper it's a spiral Dry Cell, it's alot smaller than the big truck batteries ( about 3/4 the size of the Overlander 750 cca or about the size of a 400 cca battery ). It's safer & 100% maintainance FREE. NON spillable so NO corrosion.
For any one a tight budget, the TIRGER Z 11 is well worth checking out. Make sure you can get parts for it easily & can Over Haul it regualy every year or 2 to keep it in good working order. It's a 12,000 lb winch with cordless remote & 3 mtr hand lead & works as well as any.
Mal
Ok
thats handy TJM is across where I work I might get a price on bits for the tmax.
I found another shop on the way home from work and they rekon they can get parts but rekomended I get just new motor and he could do one for $290 complete motor which isnt to bad just have to save up going up to southern 80 next week and best to save some coin.
thanks for the info
cheers Cam
millhouse13
Hope this helps
Mal
Sorry Mate - TJM winch is not a T-max winch any more -
this changed around 3 years ago
TJM now make their own winches in a factory in china which was previously owned by a company called MILEMARKER
the one tested in 4wd action was the newer style not the t-max
