winch or high lift?
poiderav4
G'day, My wife and I often go off road by ourselves and I am wondering what recovery gear would be better.
I don't have a bulbar so I can't get a mechanical winch, we don't go extreme, but I know that one day we will go too far and get stuck.
So should I invest in a high lift jack or should I go all out and invest in a hand winch.
What is the best form of recovery for a couple on their own.
Peter
dochol
Banned
I personally would go with a good hand winch first. Can be used to pull from front back or side. I have a winch on my bar at front but have used hand winch more times than front winch. Also have high lift jack and have had to use only once in two years, got stuck in some deep ruts and had to lift truck to pack rocks underneath.
Doc
Ashbine
Not having a bullbar means you won't have lift points at the front of your vehicle for the highlift. If you do go the highlift option then I'd get the wheel lift attachment as well. This hooks into your rims, then onto the jack and gives you a solid lifting point for each wheel.
RoughNReady
Ohhh, wheel attachments. You answered a question for me too. I've been wanting to get a high lift but have been stumped for lift points. I was considering making something up that could be inserted into the jacking points. You know the old horizontal square section ones for factory widowmakers? But wheels works better.
rogerazz
High lift jack and a wheel attachment is around $100.00 total.
The wheel attachment is better than jack points if you just want to lift out of ruts to pack under wheels . It lifts wheel and there is no lifting body with wheel eventually draging up.
However don't think you can use the wheel attachment to change wheels.
Ashbine
This is the wheel attachment I was talking about:
cultana
The general issue with the Hi-Lift is that you will need:
- winch kit
- wheel attachment kit to lift vehicle up.. Assuming your wheels have spokes, else it wont work.
- Hi-Lift jack plate
- Serious practice before you go anywhere.
The hand winch is all there. Still need practice though.
You will also need at least 1 tree protector and possibly 2 rated shackles whichever way you go.
I would also suggest you invest in either Maxtrack/TRED tracks as well.
If the jack is to only lift get an exhaust lift jack not the hi-lift its safer.
dochol
Banned
Remember you can also use a high lift as a winch.
Is true you can use a high lift as a winch, but you need so many more accessories to go with high lift. And at the end of the day a good winch is so much more easy to use. Plus with a block you can double back to vehicle and double your pulling power.
Doc
Out of all the 4wdriving I have done there is only one time I needed a reverse winch, came along a track and getting ready to go down as it was steep, the track had like grey dirt on it, well it was only a coating after the rain, no other vehicle marks, it was slippery clay mud underneath :eek::eek: luckily to the left of me and with quick thinking I wrestled the vehicle into a side slip the excavator makes on the side of the track to divert water, as I had some else behind me coming along I warned him over the radio to keep back,
Well we had to tie his vehicle off to a tree to pull me out, we pack up the gear to reverse out of there and no traction, decided to let his tyres down further and bingo. Now had he not been there and it was during the week and we hadn't seen anybody it would have been an interesting scenario.
I won't use or take my high lift jack because they are a lethal bit of gear.
I'd suggest some max trax and a long handed shovel first.
If you've got both of those then I'd go for the hi lift. Even with the winching kit they are cheaper than a good hand winch. Plus they're a jack as well. A hand winch is only useful at one job. Pulling two point together. At least a hi lift can push them apart as well.
I bought my winching kit and wheel attachment from Amazon. Even with shipping it was heaps cheaper than local unfortunately.
Amazon.com: Hi-Lift Jack ORK Off-Road Kit: Automotive
Hi-Lift Jack LM-100 Lift-Mate : Amazon.com : Automotive
Jesse
brumbypt
Banned
buy a bullbar and electric winch..
in the mean time, buy a good rope, then jump on youtube and look for the flip flop hand winch..
All you need to buy is a good rope, and maybe an axe to make the small logs.
check it out.
Peter,
iPad with IOS 7.0.4 using Tapatalk HD
brumbypt
Banned
you can buy an electric winch thats not fitted to your rig, but they are heavy, you then use it like a hand winch.. dunno much about them but search for them too.
Peter,
pbk1776
Go with the Hand winch instead of the high lift jack
it will be more safer and convenient to use - just my 2 cents
