Winch, Front Locker or Drawers?
mccpijs4
All cost roughly the same but I can only afford/justify one. What should I go for? Patrol set up mainly for touring, but like to go exploring too.
Reckon a winch would get me out of any trouble but I may never ever use it.
Reckon front locker would get used every so often, but might get me into more trouble.
Drawers will get used all the time, but leaves me with same issue: if I'm on my own (sole vehicle) and get stuck, drawers aren't going to help!
Maybe I just have to buy all three over the next 18-24 months....?
tankbloke
You said mainly for touring, so I would suggest Winch first, then the Drawers, and Lockers last.
muc the truck
why would you settle for a locker when one wheel needs to let go when turning . for around about the same price as locker you can have a gleeson torsen you can drive around on full lock , both wheels drive , no wheel spin . As for welding front diffs you would want it to be a cheap car you didnt care too much about . thats like having a air locker on all the time and as soon as you have to turn in the mud both front wheels start slipping and if your on a incline steering direction is lost as they are doing different track distances but turning the same speed as each. I have seen people drive sideways into a tree with a welded diff will stock standard 4x4 drove up the incline and around the trees no hastle . If you watch clips on utube about air lockers you often see one driving and the co driver flicking lockers in on the straigt and turinging them off for a turn .
baldman
Winch, drawers and then lockers if your going to use it for touring the majority of the time.
If your touring with a fully loaded vehicle your are more than likley to avoid anything that you can detour around. If it does turn to crap and there is only one way through then the winch will be your best mate.
The drawers speak for themselves in a touring situation. everything in it's own place and ease of comfort.
If your going to be using for day trips or weekend trips the majority of the time then go with the winch first and the lockers next, cos the lockers may get you into trouble where you need a winch to get out
cptmud
as previously stated build your own draws, and get a winch, the first time it gets you out of the shit, it will have paid for itself. Lockers, while being a great asset can and will get you further in the shit
nao
for touring id go winch, draws and then lockers of the three but you dont mention what other goodies u do have.. maybe underbody protection, long range tank, comms (sat phone if remote), lift...a 2inch lift and 32's will get u most places...
mccpijs4
Winch first wins it! Thanks for the advice. Not too late to buy myself a Christmas present.
Thanks for the thoughts.
The guys are pretty well spot on there mate..Winch with recovery gear,make sure you use rated shackles etc..make sure you always use a tree protector unless its a dead stump but its good to keep in the habit of always using it.....
As you'll find out there its mostly sticky clay mud in a lot of areas..Lockers (tyres) just spin on the spot once the treads become full of it..Then what ??????
mccpijs4
Yep I agree, drawers would be handy, but not when the car is sitting on its diffs!
Reckon I'll get a winch and might just make myself a false floor for the boot...
mick94surf
If you get a winch my advise is dont forget its there, make sure you service it and check its operating properly regulary. Seen many people stuck over the years with winches that dont work cause the first time they go to use them is when they are stuck assuming it would work. Be carefull of cheap remotes as they have a habbit of crapping themselves or batteries going flat at the worst time. Always keep a standard leed for backup.
Cheers Mick
mccpijs4
Noted! Reckon if I fit it myself, I'm more likely to remove it for servicing regularly. Haven't really had a look yet, but I trust I have to remove the bull bar (Patrol factory steel) to fit the winch? Same would go for removing for servicing?
mccpijs4
Avenger Mako fitted (after some drilling, cutting and grinding). Now just need to get myself stuck. Reckon I'll skip lockers and build a false floor for the back next.
