Thepuirif1er
Hello does someone know if 33-12.50-r15 will fit on my tirton mk 1999 with a Arab bull bar
Sent from my GT-I9000 using Tapatalk 2
Suggest you do a fitment check prior to purchsing them, I very much doubt it, fitted 265/70R15 to a Triton yesterday and they filled the arches out. I think 31s is the biggest they will take, maybe get some Triton owners to confirm.
I am hoping that there are some tirton owners on here:)
I doubt they would too..But i am not a Triton Owner..I'd also check with your Insurance Company too..
i have 31s on my MK Triton, they fit under stock suspension. There's not a lot of room at full lock though.
true did not think about that![]()
Yeah mate easy to forget,I think its 2inches more on the Triton Tyre Placard,probably on the inside of a door or manual...![]()
Don't forget to check full lock at full flex.
I have a 97 rodeo with a 2 inch lift and run 31' bighorns no problems. I wouldnt run 33's due to scrubbing issues and performance. If your interested Simex do a 32'x10.5r15 Extremes which will be my new tyres. As the other guys said the problem is not when your driving on the road but when your getting your flex on will they scrub under your wheel arches my 31 get close with the lift. Hope this helps.
Change of plans 33/12.50/15 will not fit at all with out a liftfound out when I stopped off at maxxis in lilydale and looked at 33/12.50 and 32/11.50 looks like the 32/11.50 will be the go atm
can someone tell me a place for some cheap steel rim with about 35mm off set
