Who has a turboed N/A 4.2 diesel
OK who has a naturally aspirated Nissan TD42 that has been converted to a turbo. My questions are: a) how much boost do you run b) what engine mods did you do prior to fitting the turbo c) how many k's have you done with this setup.
Thanks for that ruffgq I am doing it to a N/A diesel that I am fitting to my GQ, and a bloke I know has done it to his N/A 4.2 and just recently it died as he was going on a trip with the family, when he went to a Nissan mechanic they told him that 15lb boost which he was running was too much. It had started to blow the head gasket because of too much pressure. so I was interested to see if anyone was running a low boost and what sort of run they were getting out of their motor and you have answered more than just those three questions. Thanks.
bally
Banned
You can safely run 20psi+ if your engine is in a healthy condition. Iv had 2 different setups. First was a diesel central 12mm pump and tuned to 19psi the second is a standard 10mm pump and ill be gettting it tuned to 14/15psi. As long as you feed them clean air and plenty of oil thats clean also, they will keep on going. Cranks start snapping at about 700nm on the turbo gu cranks which is a lot of power and around 600nm ish on na cranks in the gq... personnely id be starting at 12psi and going from there.
Want anymore info flick me a message. Happy to help.
bally
Banned
Call diesel central in gracemere to know anything and everything about performance td42's.... its these guys jobs to make 250hp+ td42's ;)
thanks bally the motors done 500000 but has had all regular services. Crank main shells were only just worn on bottom shell and big end bearing shells were the same but worn on the top shell. The motor is good although its old so that why I didn't want to stress it too much.
Rosco
bally
Banned
do a leak down test and if your numbers come back good start at 12psi and work your way around from there.... get it dyno tuned to make sure your not over fueling it and running high egt's
How did you go with this mate? I'd do a compression test the Boost away! I fitted my turbo at 350,000 without a blink, Dyno tuned it for a 40% increase in power and dialled in 16psi with standard 10mm pump. Happy days mate, all day long. I have done at least another 100,000kms with this setup and flogged it the whole time.
As long as your running a boost and Pyro gauge and keep an eye on it and you have a good Dyno Tune then go for it mate, the TD42 loves it.
Hi Mudrunner I had it tuned at 9lb, I have 4.3/1 diffs with 285/75 16's. We are currently on our way to Fraser Island, it has put in a couple of 8 hour days on the road and is running beautifully. I could have gone more on the boost but i am happy with the 9lb setting. Yeah drive it to the pyro which I have the alarm set at 500 may even change that to 550 because it doesn't go much higher than 500 even when kept under load.
