which springs and shocks 2 inch lift mav
lost in oz
hey guys
looking at updating the suspention in the mav , not to sure what would work best , spend quite bit of time on corrugated roads going away camping and fishing ( 5 mtr tinny to come also ) loaded drawers all time , diesel eng , steel bar winch steel roof rack , twin wheel carrier , so bit of weight . i'd still like some thing that flex ok also plan on the cape next year and the kimberly also any help would be appreciated was thinking kings and koni's with rear air bag helpers . regards quinny
ball12
I would definitely be looking at some hd springs front and rear, airbags in rear. If you want good flex with a 2" lift run 4-5" shocks and adjust bumpstops to suit and grab a set of front and rear swaybar disconnects.
a simple 2 inch lift kit would do the job just fine -on patrols do a simple sway bar extension kit .
a simple bolt in kit keeps it simple and relaible with no springs falling out - I would recommend EFS or RIDEPRO
lost in oz
Thanks you all for your advice I have looked a little into efs but no nobody that runs it , I know work run the raw shocks but hard to tell if they any good as every thing flogs out so fast underground .
croozza
I second that. I see so many people have too long a shock which is not matched to the spring, and on full droop, the springs fall out. Must add, that this is a legal issue, as the spring must remain trapped.
lost in oz
Hey guys was also wonder what size wheels fit under 2inch lift currently wearing 33s just want to make sure they still fit . Thanks quinny
33s will fit easily with no rubbing -or a 285 -75 -16 or 305- 75 -16 which is equvialent in 16s .
on the road 35s will just fit under there BUT WILL RUB .
