Which Motor ??
Gator3535
Hi all ,
No doubt this has been asked before but I thought I would throw it out there anyway.
I am looking at buying another 4x4 and .. although I would love a nice new diesel, will need to save costs and go for something older.
I am looking at some 4.5l on gas/petrol patrols and L/cruisers but can also find some of the older 2.8 and 3 l diesels. I had a new Patrol awhile back in a job I had that was a 3l diesel but found it to be underpowered. Have heard bad things about the 2.8l diesels also and thing they would be very underpowered. I know the 4.2 diesel is the one to look for but they seem to be quite expensive .. is it worth paying the extra for this motor?
Is the 4.5 l petrol a strong motor ?.. or any issues with it on gas? .. wanna hear anyones thoughts.
We do plan to tow a caravan at some point soon.
Cheers ..Bruce
Plastered
4.2 ltr is worth paying the extra for as the petrols drink a little to much althou are a good motor as i have heard (Becareful with the gas ones)
2.8ltr Way under power as standard need to spend a few bucks on them to get up to speed
jack48
Go diesel, forget petrol/gas if you have the $$$$ do not get 2.8 you will be sorry My 2c worth
Split pin
If your planning on towing I would steer clear of both Petrol and gas. you wont save much if any.
I would spend the extra and go for the 4.2 dieseal. It is a cheap and easily to maintain / repairable motor with more than enough grunt to tow a good sized caravan.
Gator3535
thanks all
Just wondering why your would recommend I stay away from Petrol/gas? Is there specific problems with these motors on gas or do they loose too much power .. or .. other?
Cheers ..Bruce
As above mentioned dont go 2.8 lt ,I have a few mates and customers alike with teh 2.8 turbo diesiels -they get the job done but with effort . They have all had the heads replaced = $$
4.5 lt petrol /gas have the normal issues tuneability issues at times will lean out on gas causing it run hotter ,will need gas plugs at more regular intervals and tappet adjustments , as with all gas cars tuneability issues will arise . Over a 12month period you will not save any money on owing a gas car ,or using one for towing or 4x4ing with one .
The 4.2 turbo diesil as above mentioned is the pick ,save the extra money and if you can find one get it . the td42s arent without there little gremilns but easily overcome .
Jarh73
If you want to tow a caravan then I would cross out the 2.8 straight away. Camper trailer...... maybe.
Biggest issue is most 2.8 have high km and you never know if it has been meticulously maintained. The 2.8 isn't all bad but it does need some virtually must have modifications.
It's not "ideal" in really tough off road situations, very little torque off idle.
Justin (Owner of a low km 2.8 GU)
Split pin
:D:D:DHey why not get yourself a good GQ or a 60 series and then have a Brunswick 6.5 litre V8 dieseal put into it. :rolleyes::rolleyes::rolleyes:
Then you wont have to worry about what your wanting to tow:eek::eek::eek:
D
DONK85
Guest
I think one of the best is engine from toyota the 12HT 4l diesel.
Big Matt
The TD42 aspirated motors in the GQ is a slug, id always go petrol over diesel if i wasnt going to look at a turbo. If i was going to spend the money on turdoing the diesel then yeah its a good choise, but i could push a GQ faster than a aspirated 4.2 diesel will
Gator3535
Thanks for all the feed back. I dont think I can justify the extra cost of the Diesel so am looking at a clean 4.5 on LPG. Still not sure what too look for on these LPG conversions .. have had a Pajero on LPG and it went well. May look to upgrade to the diesel in a few years but the 4.5 seems to have enough grunt for me for now.
Cheers all .. Thanks again for your input
