which brakes for GU Patrol
our mechanic gave our brakes a check today while installing the winch, looks like we need some new ones
what should i look for in brakes?
certain brands? soft? hard?
ive read online polar opposite recommendations -from use a general car brake as they "bite" better to use specific hard 4wd brakes and everything inbetween
Traveller
I would use original nissan pads if keeping the discs, or change to slotted discs with pads to match, eg;rda rotors and ebc pads.
Westys Acc
Only trusted brands.
Bendix is a good one.
How are the rotors looking. If your up for new ones maybe invest in slotted to improve the braking a bit. If not then and your brakes are good then change the pads.
I only use bendix 4x4 pads and never had an issue..
Kallen Westbrook
Owner of
Westy's Accessories
muc the truck
be prepaired for brand new rotors . I have neve passed rotors on a full size 4wd with 100,000kms on the clock . its about all they last due to pad material being more agresive giving you better brakes. often machining is not possible as it will cut the rotor down under minimum size before getting rid of the warps and grooves. DONT BOTHER EYEBALLING IT. a dial indicator is the only way to tell if you have a warped rotor unless its that warped it trips abs fault codes and or pedal pulse.
queensland friction materaial make very good 4wd pads and PBR make great stanadard rotors and a good prices. If you do both pads and rotors you will be amaized how good it is. pbr rotors are about 125 each for a patrol at brake mart stores.
If you can aford to the grooved (not cross drilled) dba rotors are awsome for keeping pads free of sand and grit and the grooove wipes the pad clean. makes a big difference in high speed braking at say 100kms per hour as the pads dont surf on air for the first couple of mtrs of braking .
grease your brake caliper guides when you have them .
frosty
It's a GU. Should get 2 set of pads out of it. 500K kms +.
I changed my factory set at 260K kms odd. next to no wear on rotors. Check what your being told. ALWAYS check the verniers for yourself! After market pads won't see 50% of factory.
Do you want to stop normally or stop better than factory?? Expensive question?? re what Jok said.
muc the truck
verneer clipers cant detect warp all they do is measure thickness and if the veneers dont have a cut out jaw they ride on the ridge and give you a false factory onriginal reading instead of the worn thinknes . 260,000kms with no machining sorry but would fail your rotors. the ony way to measure warp is with a magnetic base stand and dial indicator .
i garentee at 260,000 kms with original rotors your not even stopping factory now
frosty
Apparantly.
I'de be concerned if it needs more than a skim and pads at that age.
Pure Yobbo
Just put ebc in the front of my GU after 190k on originals. It does pull up better now but the wheels are always covered in black crap
Sent from my iPad using Tapatalk
