Which Battery is best....
PSI 80
Hey all,
It seems that my 105 amp hour Allrounder has given up. Can anyone suggest a good second battery to run the fridge and stuff, plus the winch?
THANKS Trent
frosty
I'm running a Full River AGM now. See how it goes. The last AGM lasted 9 years under the bonnet. I replaced with a Calcium battery. What a waste. To hard to charge and not tough enough.
cptmud
im running a Optima Blue Top D34M Battery.
Optima Blue Top D34M with spiralcell technology.
Optima Blue Top Batteries are guaranteed leak proof.So can be mounted just about anywhere, vertical, horizontal etc..
Battery Model: D34M
Part Number: 8016-103
Description: High Power, dual purpose engine start and deep cycle, AGM
sealed lead acid battery.
Nominal Voltage : 12 Volts
CCA 750amps
MCA 870amps
croozza
If your going to run a winch of the second battery, then you need to go for the biggest AGM starting battery that will fit, but if you run the winch from the first battery, then use a marine battery, once again, the biggest that will fit.
It all comes down to how you set everything up, just remember that a winch will kill a deep cycle battery in no time, so it will have to be connected to a starting battery, as deep cycle batteries dont like large and rapid current draws.
Plastered
Just bought a century 100ahr marine battery today as I have heard they are good will let you no how it goes maybe soon but hopefully not
PSI 80
Agree there frosty, the calcium has been a disappointment (2.5 years), but on the other hand I have had an under bonnet heat problem since the turbo was fitted.
So Crooza......do you suggest wiring the winch to the start battery and accessories to an AGM? Is that the done thing. I have never had a winch before but because we(the family)venture out by ourselves, I figure it's safer.
We're really trying to get it sorted ready for our Cape trip in early June. "Can't wait!!!"
croozza
All depends on your battery set up, if you use a deep cycle, dont connect the winch to it, put it on the starting battery, but if you put another starting battery in as the second battery, then connect the winch to it. All the other accessories go to the second battery regardless.
I sell marine pro 720/720cc heavy duty best value aussie made!
Have lasted 7 years getting pounded in boats!
Good for accessories and cranking!
Unless you have $$$$ to spend you cant beat it!
Retail $289.00
MY PRICE $190.00
2 year warranty
Pickup from HILSIDE VIC
or
Money into my bank, delivery to your work or home $190.00....
0416111155
