Which battery for my dual battery box?
aussieanth
Hi Folks. New member, and first post. I've had a good read through the electrical threads, but cant find the info I need.
I've got a 08 Mazda BT 50 dual cab SDX with canopy this year. Its a weekener only for me and the wife, and I'm planning some 2 day to 2 week trips initially over the next couple of years, and maybe longer down the track.
Its mostly stock standard, but Im keen to install a good dual battery setup, and eventually a fridge (when I stop borrowing my parents Waeco).
So I've just bought (and waiting on delivery)
1) A JTS DSS Power Easy Box with built in Isolator & Digital Meter 12v battery box with isolator and several plugs.
Seems to have all the plugs and funcitons I'll need for now. Comes with a DIY installation kit so I can wire it into the starter battery & altinator.
I'll eventually add a 120w solar panel kit next year sometime.
2) Pure Sine Wave 1500w / 3000w 12v - 240v Power Inverter
Not the best brand I know, but I thought I would buy a much higher watt rating than I think I need, so I'm not putting much stress on it.
From this I plan to run a portable fridge, LED lighting, maybe charge a phone or laptop, and occasionally a power tool if necessary.
Questions:
A) Now i need a battery. 100-120Ah deep cycle AGM seems to be the go. Not cheap though. What should I get to adequately run my system. I wont be using it often, but it will be constantly charged up.
B) Do I need to be concerned about the CCA rating for my 2nd battery?
C) Would you eventually bother with swapping the isolator with a DC to DC charger? Or is that overkill? I believe this will mainain the battery better.
D) Could the same DC to DC charger be used to maintain the starter battery? Or do I need a separate unit?
E) Any suggestions on where in Melbourne to get a good deal on a battery?
Thanks in advance.
Watt
I was just in the same boat as you, i was looking at optima yellowtop and exide stowaway. both AGM but the exide has much more AH and is cheaper. I had my mind set on the Exide stowaway and then checked the dimensions and its too big for the spot i have set up for the battery. (behind my dual cab rear seats).
AGM is the only safe battery for inside the cab.
Anyway so i found this one on ebay which has a lower height and will fit my needs.
It is a risky buy but it has a 2 year warranty and bolt on terminals which seems good.
Plus the cost is good and free shipping... ill give it a go and see what happens.
eBay Australia: Buy new & used fashion, electronics & home d?r
aussieanth
Looks good. Seems to tick all the boxes. 2 year warranty, AGM, Australian developed/made, free shipping, Aussie supplier, high CCA rating, actual CCA test results provided. Perfect.
I ordered one last night, and its already marked as posted so I'm happy so far.
Time will tell on performance, but as Im only going to be a light to moderate user, it should fit the bill nicely.
Thanks for the tip. I wouldnt have found them otherwise.
muc the truck
thats the same batery i am buying . Nice
muc the truck
Its not made in australia , its just developed here. wich means it could be just some ones specs on plastic housing and expected cca from off shore batery maker with his sticker on it . I cant see made in australia on it anywere in the advertisement . I thought century was the only austalian car baterymaker left . I would like to be wrong .
noelh
Hi guys I am looking for a Inverter and a good battery to run it my problem is that my Inverter must be able to run a RESMED SLEEP DISORDER MACHINE it must be able to run for a minimum of 6 hours every night I am away from 240v power so does anyone have a suggestion what size and brand inverter I should run and what brand of battery to run with it
Thanks in advance for any information
Noel H.
:confused:
Mad4maz
Noel H.
:confused:
Have a look at Goalzero stuff they have power packs that will do exactly what you need
aussieanth
Noel H.
:confused:
You might want to take note of the power draw from the sleep machine, and plug the figures into an online power calculator. I'm sure I stumbled accross 1 or 2 while researching dual battery systems. They will tell you what limits your system needs to handle. Or post them on here, and someone might be able to tell you.
Im pretty sure my friend has one of those, and they dont look like they draw a lot of power, so my guess is a good 100mha battery would give you at least 2 or 3 nights use without recharge.
Someone on another forum told me: "Whenever you are going to use the inverter, it is (normal) for bigger inverters to not start "inverting" with very small current draws placed on them. ie: 1 phone charger. It is usually recommended to use a number of small items at the one time on a power board so the inverter will start and run and this also will make best use of the storage battery. ie phone charger,camera charger, AA cell recharger, Ipad recharger. all at once.
aussieanth
Well they individually test each battery & print you out a test result so you know your battery is at least above spec. Thats some piece of mind you dont get with most places.
