Where to now?
Howdy,
I'm a newbie to all this but enjoying the learning. I have a gen1 Sportage that I've spent a bit of money on making it mechanically reliable and a 2" lift. I hang out on the beach at Bribie a bit and I'd like to do some more interesting trips to Moreton and basic 4WDing of that nature. Question is:
Having spent the money, knowing the car punches well above it's weight (does really well on the beach because it's light with good power/weight) and having an older car that can have the odd scratch I'm keen to keep it and keep making it 'more capable'...but upgrades are hard to find and I wonder if I should get a $4000 hilux or similar and start with that for easier upgrades / more room for kids/gear etc ....but I don't want to get to landcruiser/Patrol size as I need it as my daily driver and that wouldn't suit me.
If I stay with the Sporty (most likely) What should I do next? I'm looking at buying a hand winch and perhaps a 2nd set of rims with bigger tyres for away-trips. I would like LSDs or lockers as I've gotten stuck in quicksand before and you could see 1 wheel sapping all the 'go'. That being said lockers are not an off-the-shelf item for kias! Budget is a MAJOR issue, so I'm thinking hand-winch next? (I have a snatch strap and shackles/compressor/shovel as my recovery kit so far). Any advice appreciated.
The other thing I'm thinking of doing is removing all the internal carpet, front and rear plastic bumpers and other stuff to reduce the amount of stuff that can come off and make it easier to clean out at the end of sandy trips!!
Cheers,
Rob.
Kody
I have a Sporty, a late 97 model. It is a fabulous vehicle and goes almost anywhere. I bought a 4 foot long High Lift Jack for it (made in the USA, not China) and about 14 feet of high tensile 8mm chain with all the hooks and chain dogs as needed. You can pull the Sporty up and out of anything with the High Lift and it fits nicely across the back behind the rear seats. I would give the bigger tires and wheels a miss as you will find it will lack the ability to climb hills. If you go the High Lift or any other hand winch, toss in a high quality axe as well and make sure it's sharp. This will cost at least $90 if it's a good one. Don't buy a cheapie that costs only $35 or $40 bucks. Youtube has lots of excellent videos on using a High Lift Jack. When using a High Lift Jack, safety is essential as they can be very unstable if used without lots of care. You will need a tow strap when winching the car, don't use a snatch strap, they are not designed for pulling from a winch.
Kody
80lover96gxl
If you do alot of sand driving get yoursefl a set of maxx traxx,very handy in the sand and can make for a quick self extraction from a sandy bog.
A high lift jack can also be used as a hand winch using the correct safe proceedure,learn how to do this.
As you do more and more trip you'll soon discover the sporty may not cut the mustard,as your confidence and skills develop you'll want to try harder tracks or dunes,this is where a Hilux or something similar will come into it's own.
Get youself a decent cheap hilux or duel cab of some make ,you can fit your bigger tyres,plenty of after market accessories and you'll thank yourself down the track.
Just my opiniun mate,good luck with it all.
cheers,
Brian.
Thanks for the responses guys :) Will stick with Sporty for now, I've been doing lots of research and I'd have to spend quite a few thousand to get a Hilux in similar condition and getting the Sporty where bigger guys go may be a fun challenge. I think I'll start shopping around for that hand winch, but I guess I'll need a land anchor for the beach...Big thing I HAVE decided to do is sus out a local 4X4 club so I can do a few trips with more experienced people :) .....besides might be easier to winch a sporty than a 'lux :p
devo73
Banned
Why are recovery points always overloked as the 1st purchase :confused: No good having lockers, winch blah blah with nowhere to recover from when ur deep in the poo!
People will be hesitant to recover you (i know i would be) without rated points so get them fitted asap.
Other than that i wouldn't do a single thing to the Sportage. Why spend $$$$ on new accessories when, as 80lover96gxl said, "As you do more and more trip you'll soon discover the sporty may not cut the mustard,as your confidence and skills develop you'll want to try harder tracks or dunes" I would put every cent of upgrade money into a "buy another 4by" fund, and you wont look back (well only at the Patrol ur about to recover ;))
P.S. i did say another 4by NOT "real", or "proper" or anything else denigrating so dont jump up and down :)
All good, I appreciate the advice in the sentiment offered :) Sporty has 2 recovery points on the front and an 1800kg bar on the back that I use for recovery (on the rare occasions it's required - I tie around the bar which is bolted to the chassis (not body) and I don't tie to the tongue/ball). I guess I'll probably buy a hand winch and leave mods at that, see how I go and if I get stuck too much consider another 4x4. Just off-putting that the 1st $5-7k would be on a standard one at the same mechanical condition as Sporty, and then more money for mods from there. :)
