wheel bearing problem hilux help plese
ando95
rebuild my hubs and done wheel bearings every few days they come loose and i not sure why i have done the locking tabs all buy book still cant pick why any input would help and has anyone had problems with the birfield joing i think it is on the axle solid axle ofcourse i feel a little vibration and grinding onnly in drivers floor could that be the problem
muc the truck
maybe you never hammered the wheel bearing cones in far enough . please dont tel me you sued your olds owes as this hapens too often in the backyard. old cones new bearrings - new car some times.
tighten your bearings up as tight as you by hand while some one is turning the wheel . then back them off . then adjust the bearings as by your book.
ando95
new cones for sure tabs al bent over and tightent all the way up but still comming lose ? i stumped
muc the truck
are you sure its not swivel hubs being loose and incorectly shimed. this is often stuffed up and its a trial and error with shim stacks to get it right , you do not just use the shims that were in there to begin with.
prior to locking tabs on bearings did you tighten the bearings up as hard as you could by hand while some one was spining the wheel. as this seats the cones.
ando95
i did not rebild hubs shop done that and i did go as tight as i could while gf sppining wheel but still getts loose
muc the truck
some times when a bearing wears out of ajustment it strips out the threads on the lock nuts . not enough to completly strip but enough to render them sinkers for fishing.
while the lock nuts are loose if you can rock them on the thread toss them away. some times its a new stub axle as well.
siezed caliper andor shity rotors are allso a culpret for loading up wheel bearing lock nuts causing wear. if your rotors are not up to scratch go here.
Brakes Direct - Search results for: 'hilux'
consider grooved/sloted as they wipe sand and grime from your pads and stop considerably faster . I have fitted them on a number of vehicles and have had comments back like shit the dog hit the dash the first time i used them . they make a difference but them again so will stock over stuffed. same with machined drums .
ando95
ok ioll have a look at the nut movement and have a loo into the brakes thanks man ill post up what i find big help btw cheers
