What tyres to get
skipie
Ok I'm starting on my new build and I'm trying to workout what rims and tyres to get
Now the price of things won't worry me much
They will be going on a gu wagon
I'm after 37's or near enough to 37's it's only going to be used on weekends
I'm just after peoples ideas and feed back on what has worked for them
Thanks
Chris
Towie
What sort of terain will you be driving in for the majority of time?
What engine does the GU run?
Gearing will be an issue whats your plan there?
15 or 16 rims will do i think 16 nch tyres have a higher load capacity if its going to be a big heavy rig..
Why 37's & not 35's?
JT2's are a narrower tyre in big sizes which will help with scrubbing otherwise you will need spacers or deep dish rims or do some chopping i think .... 36 x 11.5 x 16 is a good size imo unless you want or need the width...
ball12
If I was to run them again I'd be going straight to creepie crawlers or the pro comp x-terrain. Both handle clay, rock and mud really well and have lots of sidewall protection and flex
frosty
I've seen the Kreepy's workin. Awesome tyre. I'm runnin 35's in a Bighorn. Great tyre.
Don't know why you'de want to run 37's??? Make the Patrol stick out for the anti fun squad. Must be real big rocks?
justaguy
I with Frosty here... I have 33's Bighorns as well... if you do the cost benifit ratio... they are hard to pass up. out on the weekend in the mud and no lockers... not a problem in the world....
Towie
Treps would be good also & i think 35's are ample for a play rig...
i run a set of 35 x 12.5 x 16 Creepies & they are awesome on road pressure 25 hot & drop them to 12 easy on track but you will pay around $500 plus a corner & they dont last long..:eek::(
I will go back to std muds in a 35 next time around which wont be long at the rate they are wearing out..
Elbie84
If your going 37's either go Maxxis Treps radial compound if you want more km's than the stickies but you will have to run 17inch rims though, or you could go Pro comp xtreme mt.
I used to run maxxis creepy's thought they wern't to bad but wouldn't buy them again didn't balance to well in 37's, they were not the best in mud either.:(
I run 37 stickie treps on walker evans now and no other tyre compares:D
A mate runs the Pro comp xtreme mt on his comp truck and i rate them as the best radial's ive seen but they are very $$$$$ i think he paid $720 a corner for 37x12.5x17
Hope this gives you some help.
ball12
wow 740!!!!!!!!! my mates just put the same tyre on there comp truck for a LOT less. like swith your 7 and 4 around and thats what they paid each!!!!!!!!
dudelux
Id pick Swamper SX, if you can find them.
I run normal Swampers on my Lux, 33x12.5x15, and they are fantastic everywhere. they are even good on road, just noisy.
Elbie84
GEEES, Can you please find out where he got them from and there number and PM them to me please. Are you sure there the 37x12.5x17 part No 671237 ??????
From pro comp direct we can't even get them that cheap for the Xtreme M/T 37x12.5x17.
For that price you have said, we can just get 265/75R/16 or 32x10.5x16 for:confused:
Please PM details through:D
ive got a couple of customers runnign around on 37 12.5 17s normal muddy -they dont use there simexs anymore and they run the procomps on the road all the time ( yes 2 of them have 37s on there daily drivers ) at full retail 37 12.5 -17 muddy $520 a tyre xtreme muddy same size $740 a tyre and x terrain same size $ 645 a tyre .
CHUAH
Here's my two bit...
Mickey Thompson MTZ 315/75/16 (35") - Good tyres for off road, soft compound, wear quickly...
BFGoodrick KM2 M/T 305/75/16 (33") - Good tyres, better wearing compared to MTZ, good for off road, I did however had punctures on the side walls (more then once) and the tyres keep coming off the rims at about 20 psi (I'm only compareing this to my personal experience compared with the MTZ, with the same type of useage)
Now using the Pro Comp Xtreme M/T 315/70/17 (35") - So far so good... side walls seems alot tougher however is about $100 more expensive then the MTZ and KM2, I paid approx $540 each...
For 37" why don't you go for the Maxxis.... ummm not sure the name but they have a seriously mean awsome tyre!!
Cheers!
