What to replace when doing the timing belt service?
85L200
I'm about to attempt a timing belt service on my 1998 V6 MK Triton. It will be the first time doing a Triton. It has massive oil leaks, I can't pin point exactly where, I think from the cam and also the tappet gasket.
I'll do the spark plugs while I'm in there and the water pump. What gaskets and what do you recommend I replace while I'm doing the timing?
Also do I need to replace the hydraulic tensioner? As it seems most kits on ebay don't provide it?
And will any 6G72 timing belt kit be suitable?
Also my MK blows a little smoke under load and when I take off... I'm assuming the valve stem seals are going/gone? Is this an easy job?
Thanks
If your Triton is like my Ranger, I did the 120k timing belt early at just under 100k (before another big drive) . . . I bought a kit, had belt, tensioner, everything generally replaceable, including seals for cam shafts.
My mech said if the seals aren't leaking, leave them !!
Wish I'd listened to that advice, they are easily damaged, and I had to get another one in the middle of the job.
Yours of course might need them done by the sounds of things.
Yes, very good idea to do water pump at same time.
Valve stem seals are usually a little more related to a lot of smoke on start up (after sitting a while).
