What thermal pants do I need?
Chriso100
Hey there all,
Going up to the Vic High country in a couple of weeks. We are staying in swags, and doing some big walks during the day. In some points I will be taking breaks on the walk and sitting and waiting. My question is....what sort of thermal pants should I buy? I've seen all sorts, merino, polypropylene and others. They also range from $25 up to $150! Do I need to spend heaps?
Cheers Chriso.
peterfermtech
The Merino if you can afford them. They are great! Thrown all my poly thermals out now but still keep my polar fleece. However if your walking and then resting I think the better combo would be the lighter weight merino with a wind/water proof pants to pull over when you stop.
regards
TonyF8
Morning.
My other half manages a camping store, so I mentioned your dilemma to her.
She suggested merino wool and check the rating (thread count), It should be a number like 190 and going up from there, that being, the higher the count the warmer the thermal, you will need to take into account what over clothing you will be wearing, more thinner and lighter rather than 1 big and bulky, that way
you can adjust your clothing as to conditions.
Hope I've been some assistance.
Tony F8.
Paddler Ed
I like these; I picked up a pair for a cold winter in the UK and used them a lot. Thomas Cook do a version over here, but the lining isn't as thick.
cloughcarib
If I was just in and around camp then I wouldn't have an issue with poly thermals(I say if, but that's me). They do a great job of retaining body heat, but it's a bit of a catch 22. Poly thermals don't breath, so the more you heat up, the temperature keeps rising to the point where you're uncomfortably hot and sweating. When you stop the poly does not retain the heat so you end up cold and damp which is a horrid.
Merino thermals come from the wool of a merino sheep which have hollow fibres. The hollow Fibre not only traps latent heat, but breaths to allow your bodies moisture to escape.
Hemp has similar advantages but works slightly differently. I've yet to see hemp thermals though
From the OP you'll be walking so I personally would suggest wool. If you can afford good merino that's good, but any wool will be better than poly if your exerting yourself.
Gavo
I'm with everyone else. Merino! I spent quite a few years working in the snow. I've tried them all. When your working flat out then stopping merino comes to it's own.
Yep they're expensive. But they're worth the money.
Pretty sure everyone else has summed it up better than me :D
