What spare parts should I take?
Connormxe2
Hi there I'm reasonably new to 4wd'ing and I was wondering what spare parts should I take out with me and what tools should I take. I drive a 98 hilux.
Depends mate, how far, how isolated, how rough the conditions are, how good a nick the old girl's in.
Remote desert type trips, change of belts, radiator hoses, oil / air / fuel filters, some spare oils, some repair stuff like liquid steel, radiator patch up stuff (2 types), tyre plug kit, some of the tubeless tyre patches and glue, and a spare tube . . . that's on top of second spare.
People often take a front and rear shocker, but where do you stop ?
Taking too much stuff can put more pressure on load total, and place more risk on having something break in the first place.
If going with others, you can take less oil for example if each has a litre, same with a lot of other things.
Share tools in a group too, basic spanners, socket set, screwdriver assortment, anything special for front end spanner sizes, always take duct tape.
Desert trips I take small right angle drill, hex head teks, drivers, and some strapping to temp fix things like exhausts or other things that can come loose.
Never had to use it yet, but the first time I leave it home you can bet we'll need it in the group, or for someone else out there.
Just think about it in a common sense way . . . What is possible to break on this trip ? What can I fix myself out there ? Anything beyond what you can do, it's no use taking, have good cover with auto club, good insurance, and hopefully a good pinch of good luck.
Agree with Les
One item I would highly recommend is the top roadside service cover not just the standard one
We have used the service a couple of times getting towed back home from remote places ( still on gazetted roads) and provided hire cars and accommodation all free as part of the service
Well worth having if you are going touring
PTCX
Always carry an assortment of cable ties,a pack of the largest you can find as well.It's amazing how much you can fix with cable ties and duct tape.
Some rescue tape is a permenent fixture in my tool kit,very versatile stuff.Most 4x4 shops carry it.http://www.rescuetapeaustralia.com.au/
If your heading out to places with lots of corrigated roads take some spare nuts & bolts,self tapping screws and some tie wire or fencing wire.
billolga
I have used cable ties on two differant vehicles in two days to make a fan belt bypassing seized alternators. The second vehicle drove 180 kms at 80 kph towing a Caravan.
And if you drive a 76, a spare diff or 2 won't hurt either.
Or if a 80 a couple of CV's is a great idea, I have removed 2 Toyo CV's out bush, touch wood never a Landy CV
MMM and to think of it a Hilux did a CV last time I drove Phone Trk. too
OH WHAT A FEELING TOYOTA
Gavo
Spare parts is such a gamble. I carry some basic bits and pieces. Such as radiators hoses, filters, an axle (once bitten twice shy).
Obviously emergency parts such as cable ties etc ate an easy light weight.
I think if you know of any particular well known issues with your model, wouldn't hurt to chuck them in.
richardlnsw
You think Toyotas are the only trucks to do a CV???? You really are biased Matt aren't you... or very jealous.:)
Belts and hoses, fuses etc. but don't overdo it. You will end up carrying stuff just for the heck of it. Make sure your truck is well maintained before you go and do regular checks on the trip.
You bit Richard :D
I have a spare torsion bar mount cradle now after Red Centre trip, where it was welded up at Mt Dare adequately.
Will I take it on future trips, just in case ?
Yes, pretty much any trip stressful or remote.
I just have to do a little mod on it at home to be able to use it left or right side, then it will be doubly useful to carry.
Maybe a little biased, maybe a little jealous, would love a 80 and could have a nice turbo diesel for what I have poured into mine:oops::confused::(
but the reality is that over the years I have only seen 4 CV's let go out bush 1 Bitsamissing and 3 toyo's
once again touch wood never a Landy but I am sure my time will come, especially the type of wheeling that I tend to do;)
I guess that's why, as you suggested Landy owns tow a complete Landy the whole vehicle is no better or worse than any particular parto_O
richardlnsw
Don't jinx yourself!!!!
With a lot of breakdowns I really think that the driver pushing the vehicle way too hard has been 80% of why the vehicle "let go". But that's another thread.:cool:
I shouldn't have said "carry for the heck of it" as if needed only once then it was worth it. It's just that I have seen people carry so many spares which adds to weight and takes up room. It is a difficult one to answer as everyone has different ideas.
Pick the bones out of all the responses and go from there.:)
stevemc181
I carry most of my tools and some welding gear, tyre change gear the usual radiator hoses/belts and bit and pieces. I figure if I break something bad enough I'll get on the Sat Phone and have whatever I require delivered to the nearest town. Then work out how to get to it or how to get it to where I am! If its trackside fixable I'll get it going.
As richardlnsw says, most breakages are generally from pushing too hard in the wrong kind of terrain. Vehicle sympathy goes a long way to avoiding trouble, but sometimes shit happens and things break. I like to think I can limp out of most situations, but these days the all mighty computer module may dictate other wise.
One essential Item to carry in a modern 4wd is a Scan Tool of some description. This at least gives you the ability to read most fault codes and in the vast majority of cases you can clear them and carry on, rather than dropping into limp mode hundreds of km's from anywhere.
IvanTheTerrible
We take both radiator hoses, brake fluid, engine and gearbox oil, duct tape, two spares wheels, a repair kit and tube, tyre levers and a soft face hammer.
Tools: I have a man bag with hand tools and a Wurth brief case tool kit.
Chatty
I would suggest:
  • Multimeter - for diagnosing electrical issues
  • Butane soldering iron + rosin core solder (0.7 or 1mm) + spare butane - good irons are more reliable, and you want the little blow torch and hot air heads for it as well
  • Selection of heat shrink - I use the Jaycar pack - they're only short lengths, but lots of sizes and colours)
  • Good insulating tape - the cheap stuff never sticks
  • Wire cutters, blunt and long nose pliers - add a wire stripper if you want
  • A reasonable selection of wire - I carry a few metres of red and black in a couple of heavier gauges, working on the basis that heavy wire will fix a light current problem, but light wire wont fix a heavy current problem
  • Selection of crimp connectors and a good crimping tool - one with a ratchet action
  • Inspection mirror on a stick - I have one with a light
  • Magnet on a stick - I have an extendable one with a light and a flexible one for the difficult spots - because there's nothing worse than dropping a nut down a cavity where you can't reach
  • A gold old fashioned wire coat hanger or three - they weigh nothing and can be used to tie things up, make hooks for fishing things out of hard to reach places and a thousand other uses - if all else fails you can hang your clothes on one too!
  • Cloth tape - get the heavy black stuff - it sticks better than duct tape and is a lot stronger - it can be used for all sorts of things
typhoeus
And, if your not really familiar with things mechanical, a workshop manual could be very useful. you don't want to be pulling something apart the wrong way in a hole somewhere and "sproing!!!" . . a whole heap of small parts disappear into the mud. . .!
