BTFIVO
Hi all,
I'm looking at supporting and sustaining the electrical system in my caravan. I currently have one 100Ah deep-cycle battery and one solar panel down to a regulator/charge-control box that indicates charge and load of the 12v system. I have a 240v system when connected to mains or generator and the 12v system with vehicle-type female sockets. I also have an anderson plug to the front to connect and either run or charge my vehicles 12v battery. As it stands, my caravan is self sustaining to an extent, but at only a 100Ah battery... not for very long. I do have a 2200w inverter generator as well when out field for either 240v/12v and has provisions for 12v battery charging as well. I would like a larger genset to run my A/C, microwave and every other 240v appliance at the same time, but at the present, this one powers my A/C + a fan well enough. I haven't tried the microwave with the A/C on at the same time yet. That would be about 2600w together I would say.
So, what I would like is two 150Ah batteries with two 150w (or greater) solar panels down to a control-box, to a 300w AC-D/C inverter, then spliced in parallel with 240v to the 240v circuit and 12v to the 12v circuit.
This is just a ball-park figure as if I can find larger capacity solar panels and batteries, I will install them instead. I basically want 240v off solar, self sustaining. I am happy to use my genset for the aircon if I still have to, etc.
I'm pretty sure my A/C is 1800w as the previous owner stated they couldn't run anything else off their 2000w inverter genset. So with a 2000w genset, the nominal output would be 17-1800w depending on manufacturers quality/efficiency. Mine in 2200w and 2000w nominal, which is why I want at least 28-3000w nominal capacity.
To this, what are people running, both set-up and brands. I am looking at buying BP Solar for the system, but have to further enquire on if they have batteries. I've also seen some off-grid 12-->240v systems at exceptional prices on fleabat from china, but not sure of the long term quality. I definitely don't want something that will burn the caravan down..!!! eeep.
Cheers. Pete
Cheers. Pete
