BILLBY
planning some mods to the centre console which will require some extra wiring, okay a lot .
looking to instal 2 switches for spotlights 1 for the reverse spotie another for the fridge and a few spares . question is is 6mm big enough ,I am a plumber,if I need more water ,I place in a bigger pipe however if the source is no bigger I get more volume but a reduction in pressure does this follow with auto applications.
I have bought 4mm x1.85 wire to feed each switch from a 6mm feed breaking it down into a six way fuse box, looks okay as I can solder and covered it all tape.
1 off the points is for dedicated power supply to garmin thru a ciggie lighter fitting.
Thats five points, I do not know ratings and stuff but willing to give it try and understand if you speak slowly.
my panel currently includes oil pressure gauge all the locker switches 6 switches for the accessorries 2 ciggie plugs 1 from main battery the other off the second battery all with led lights carved out of 3mm aluminum plate. I would like a 12v clock say no bigger than 50x50mmso any ideas would be appreciated
