Here is a translation of the attached image. I should add, its not my translation, i found it.
Quote:
The Saurer five-axis SUV
As a peak performance in the construction of off-road vehicles must be new Saurer - designate five-axle. Its load capacity is on the ground two tons, three tons on the road. Here, the car's speed at full speed of the machine 4 and 4-65 km/h. be varied. The climbing ability is at the bottom to grip percent.
Acid - - As The power source is a six-cylinder diesel of 105 mm bore, 130 mm stroke ie 6.75 liter displacement. The power is 90 horsepower at 2000 rpm. In order to ensure the proper running of the engine even during continuous operation on steep ramps of 50 to 60 degrees, dry sump lubrication is provided, and this secured by a triple pump. The chassis has, as I said, five pairs of wheels for polishing off-road capability, it can be 1.5 to 2 m wide cross trenches and drive through 80-cm-deep waters.
The front axle is a so-called climbing axle, which may be optionally driven on or off by the driver. Then follows the intrinsically Fliche first barrel supporting shaft, which is only used for supporting the vehicle on short, but high unevenness in the floor. Then lined up at the both rear axles. The front axle and, both rear drive axles are trained as swing axles. Each impeller may be radial in the vertical plane, a deflection from 450 to 500 mm. Despite low laga delay of the engine he
Despite deep storage engine results from its frame design, the high ground clearance of 310 mm. Additionally, the frame is covered below, so that it can over stones and the like, slide without danger to the four-speed transmission. Away from the engine, the clutch plate toughened concerned the power transfer to the four-speed transmission. An auxiliary transmission with two levels increases the number of gears on eight forward - and two reverse gears. The wheel drives have double reduction by a spur and bevel gears; replaceable six-wheel drives are identical and each other. In slippery terrain automatic differential lock prevents the wheels from spinning. Mitigated are the wheels by torsion bars with hydraulic shock absorption. All six wheels are braked Duch Oeldruckbremsen. The track width measures 1.5 meters of turning radius outside front 5:25 m, the chassis weight is 3000 kg, with equipment and leveler 2700 kg.
