What is this thing?
4runnerSteve
Sorry for the dumb question, but i need to know what this is.
I've been trying to figure out what it is since i got the car, but to no avail. It is behind the bumper on the right side of the engine bay, under the air filter. The bottom hose appears to be a breather. The fat one on the top right goes back to the fuel tank, and the one on the top left goes up to this thing, which is plugged into a wire that goes into the loom to got knows where.
My girlfriends diesel version of the same car hasn't got one at all, so I'm trying to figure out what it is, and what to do with it when i put a diesel in this one.
Thanks in advance guys.
Chatty
It looks suspiciously like an activated carbon canister - used to filter petrol vapours (fumes) off the fuel tank, so they aren't released to the atmosphere. The electric gizmo looks like a solenoid to allow air to be sucked into the canister when the engine is running - the "breather" pipe should be connected into the air intake system somewhere - quite often at the air box (filter box).
The petrol fumes are "trapped" inside the canister and then sucked into the engine for combustion when the engine is running.
Not used on diesels as the fuel is much less volatile and doesn't give off significant vapours.
Hmm, a bit of a mystery to me mate, obviously something to do with the fuel system, and a sensor of some sort (pressure ?) ?
NFI, but will be good to know if someone does have a clue about it.
Could be anti pollution type of apparatus ?
GUnka
Definitely an anti pollution carbon canister to vent fumes from the fuel tank. The other thing would most likely be a pressure switch there to sense excessive positive pressure if the filter becomes blocked. It definitely wouldn't be sensing very high levels of pressure. What you could try is bridge the connection and see what comes up on the dash/happens or put a spare length of hose on it and put some pressure into it either blowing or with a bike pump or something similar.
GUnka
Btw, if changing over to diesel you can just leave it there. It wont do any harm.
4runnerSteve
Thanks chatty, I thought it could have been something like that. The breather just goes straight out into the bullbar, not back towards anything, but that dosnt mean its supposed to be like that, not much is how it should be on this rig.
So for the diesel conversion, should i leave it all as it is, or block off the pipe coming to it from the tank?
ill attack the sensor and see if it does anything tomorrow.
GUnka
Normally the breather would go into the inlet manifold/tract somewhere as is always under negative pressure, Into the bulbar is definitely not factory. No I wouldn't go blocking the pipe off the fuel tank as you still need it to breathe. If your going turbo diesel you probs don't need the cannister but wont hurt to keep it but I would run the breather to somewhere high in the engine bay like the top of the firewall or something.
4runnerSteve
Thanks gav, I'm thinking i might run the breather up into the air intake, then theres no chance of water getting into the tank through it. There is another breather in the diesel filler nozzle that Ill be fitting, but a second breather won't hurt will it?
GUnka
Nope. :)
