I guess coolant is coolant. Try sticking with the pure stuff but at the end of the day unless you are in really cold climates the pure stuff isn't compulsory. I use the Nulon in my rigs in a pure form. No water but I use it cuz I can afford it for no other reason.
mot quite right, i believe in the red coolant a phosphate inhibitor is included to provide several important functions that help reduce automotive cooling system damage. The benefits provided by the phosphate include:
* Protect aluminum engine components by reducing cavitation corrosion during high speed driving.
* Provide for corrosion protection to ferrous metals.
* Act as a buffer to keep the antifreeze mixture alkaline. This prevents acid build-up that will damage or destroy metal engine parts.
the green coolant can cause damage to aluminium heads, and that's why Toyota recommend the red coolant
