WD40, Linolin lubications for underbody maintence...
CHUAH
Hi all.....
I am giving my GU some lovin and have usually been using WD40 under the car ie chassis rails, drop arms, steering arms basically every metal bits in can see under the 4WD...
Is Lanolin better? is there anything specific that I should not go near with my maintenance etc...? I usually do everything electrical or not! I heard Lanolin is better for O rings etc...
What do you do? If any? What lubication or rust protection spary can you suggest?
Cheers!:D
LowLux
Hey there. Good idea to do what your doing. I do it too. I use Lanolin for the steel work and WD for the electrical areas and it seems to work just fine.
allanmac
I use both...:D
WD40 helps with removal of mud.
The thing with Lanolin is to let it 'soak' in for at least a few days then polish it with a cloth. Learnt this from our last trip to Tassie...:eek:
If you just spray on, things like sand stick to it like 'you know what'. If you give it a bit of a polish, you will find stuff like sand or mud is easier to remove. I will be giving my car a thorough coating before we head off to Tassie again next month as we will be doing fair bit of beach driving.....:D.
Just ensure you have removed as much road grime as possible before applying.
Pure Yobbo
I use the cheap Super Cheap brand WD40 not as much oil but still works a treat. Used it for years on my jet skis and they still looked like new when I sold them. If you use the good WD40 tends to smoke too much when it gets hot.
CHUAH
Is Lanolin still ok for electrical components?
Do you guys spray these stuff (WD40 & Lanolin) under the bonnet as well? Where? What?
Also, how often should we do a property spray out? 6 monthly?
Thanks!
Pure Yobbo
Thanks!
I spray everything with the cheap wd40. Especially when I have been up the beach. Other than that don't have a reall set timeframe for the 4by. Ski's used to get done after every use when they went in the salt.
allanmac
Thanks!
I have used it on both, but again XQZME the key is to polish it with a cloth after a few days. I tend to leave it for at least 5 days before using some 'elbow grease' with the trusty old rag.
Must admit, I prefer the WD40 or similar on all the electricals under the bonnet. Everywhere else the lanolin.
InGoodCompany
Lanolin for the chasis but as others have said if not cleaned off will accumulate sand and worst of all salt. A good cleaner like the Staun Masojet can help remove the sand from those hard to reach places if it does accumulate.
