Water Tank
MK_Duncan
Gday guys
seen a few threads on PVC water tanks on here so i got a few questions for you.
whats the best way to install a tap in the end cap of the pipe?
and also to get pressure can i run my existing air compressor into the system or should i install an inline water pump to get pressure?
cheers
MK_Duncan
any thoughts to pressurise the system? and do i have to tap and die the end cap or will a rubber oring on both sides be sufficient?
marty e
Just get a bilge pump ...pump straight from a bucket of water
Sent from my HTC One XL using Tapatalk 4
cloughcarib
There's no real reason you can't use air pressure, just make sure the PVC is schedule 12 or 18 and you use pressure glue that's suitable for potable water. Your local Tradelink or Reece will help you out. Definitely drill and tap a thread into the endcap using Teflon tape to seal it
