Hi all,
I recently replaced the water pump on my 2015 VDJ. Now, pending how I’m driving, the dashboard temperature gauge oscillates between just below half and just above half. Prior to water pump replacement it always sat just below half. I haven’t been brave enough to get the temperature gauge above just above half. My heater also doesn’t work.
I’ve attempted to bleed the heater pipe using the little rubber plug but only get intermittent spluttering. I’ve also attempted to bleed the top of the radiator but get steam, no coolant coming out.
Also, when I turn the car off and remove the cap on the overflow tank, coolant seems to flow back into the tank.
Is there anything further I can do? Any advice would be greatly appreciated. I’m remote so I’m pretty much on my own.
Cheers,
Tim.
Cheers,
Tim.
