Water in fuel filter warning light Nissan 3L
Bullet67
Gday campers, I am new to 4x4 the reason being I have a few minor issues with my 03 Patrol that I need to sort out and would appreciate any feedback / Comments. Can anyone help with this one? Coming back to Perth from Busselton yesterday i had the following warning light appear on the dash "water in fuel warning" :eek:. I pulled over for 10min, let the donk cool, and on my way again, light disapeard:rolleyes: but came back again :mad: Just before I got home I felt the engine slugish and if the description is correct I guess the engine would be starving for fuel? Any one else had this problem, I what did you do to resolve :eek:.
Glen
frosty
Guess who's got bad fuel!!
Dump the fuel in your tank. New filter. (2 or 3 times) And bleed the injectors. Get a sample of the fuel annalysed and if it's bad, send the place you got the fuel from, the repair bill.
Frankensurf
Is the warning about water in the fuel, or water in the filter? I don't kow about patrols, but the hilux fuel filter collects any water out of the fuel and a light on the dash tells you when it's time to drain the water out of the filter.
frosty
Get a fuel separator fitted.
Welcome to 4x4 Earth.
Yep. Do that. A cav filter/water separator. The filter you currently have does a similar job. But is much more expensive and you can't see the water. And 2 filters are better than 1!!
Rocker
As Frankensurf says, you've got water in the filter. You'll find there's a small drain valve on the bottom of your filter with a tube running off it - undo that and let it flow.
Sometimes it means disconnecting the wires to do so, but make sure you plug them back on so the warning light works again next time.......................and I'd probly change the filter at your earliest opportuntiy too !
jazzajess
i had same issue changed filter after i ran full tank through from when light came on and drained everytime it did then have not had problem since...
Bullet67
Water in fuel THANKS
Guys, thanks all for the comments. The Nissan is parked up ready for the shut down and the 1984 ford laser is rolling the streets again.
Glen;)
billolga
As a note, the TD42 engine has a "Water in Fuel light" - The 3 ltr uses the Engine management light & you have to read a code 0707 to find out. (Easy to read the codes - even the Gregory's Manual tells you how using a piece of wire).
