OzyTourer05
Hello,
On the weekend I got bogged a little deep see pic but immediately killed the engine. No snorkel.
Once pulled out I checked air filter which was damp to the top and the cold air intake had moisture. I think more so from the splash on impact, definitely was not submerged or drenched.
I removed and cleaned the intake hose and sprayed wd40 in the intake and on filter. And a bit of "start ya botch spray".
Car started fine and does not seem to be running poorly.
Is there anything else I should do to know if I have caused damage? I have read a single drop of water can cause the chamber to fail.
2007 Diesel R51 Pathfinder which is common rail diesel turbo, the same front as a D40 Navara.
