There are a variety of pumps available on eBay depending on your requirements. The conversion will be quite simple, all you'll need to do is replace your hand pump with a tap, work out the best location for the pump and wire it through a fuse and switch. Most pumps these days have a pressure switch, but always put a switch in the circuit in case of breakages or maintenance.
