Wash Underbody of sand & salt
Jimmyranger
Hi,
Could someone possibly advise me on the best way to clean the underbody of my 4x4 of sand & salt. I am very concerned..through complete ignorance I drove my brand new Ford Ranger on the beach today at Kurnell. I drove it on the wet sand & a couple of times through 2-3 inches of salt water. Afterwards I was informed about the rust issues this could cause. I took it too a car wash and they cleaned underneath it with a spray gun & when I got home I sprayed as much of the underside with fresh water from the hose.
Can anyone advice me of the best thing to do here. I'm really concerned this will cause damage to my vehicle. Have I stuffed my new 4x4? What's the best thing for me to do?
I won't be driving close to salt water again!!!
Concerned
chris_stoffa
Just move it along under the vehicle - Works for me as well as a good flush with the garden hose into the nooks and crannies
80lover96gxl
Also get undet there with the garden hose and give your chassis rails a complete flushing,,front n back, both sides until clean water if draining out all holes.
Flush gearbox crossmember and any underbody guards thoroughly, all bushes and suspension components, fuel tank bash plates, behind bumper bars, bull bars and the like, brakes. Everything.
Whenever I do a beach run it takes me easily over an hr to thoroughly flush the underbody of my trucks, and yes you will end up just as wet as everything else under there.
nightscale
You can also get the 90 degree elbows for gerni's etc which help alot with getting soaked like brian metioned
darb
Just time with the hose guy. Don't stress your truck is not about to start rusting to death.
Many of us have frequent runs along beaches and frankly the overnight csmping in beach with salt mist and subsequent condensation probably does more than a bit of splashing.
Just get under her with hose for 20 minutes and flush everyhing at end of each trip.
You bought her to use her, get out there and have fun. Be sensible of course don't go driving through salt water if you csn avoid it (sometimes there's no choice), but other than that don't stress.
Not to forget most new 4wds are very well sealed and painted.
Superdad
Not sure where you live but i am close to a dam with a boat ramp. I drive my Cruiser into the freshwater and give it a good soak.
seems to work pretty well
Towie
Yes i have some creeks n rivers near home we use 6 or 8 crossings gets the bulk off the 4wd but IMO not all the hidden stuff certainly not the chassis rails & inside the bull bar rear bar under slidders etc or the bash plates as mentioned above.
Infact its amazing just where it gets to & hides im really annoyed now as knowone told me this before i bought a 4wd where is the warning about all this cleaning we have to do afterwards.
chris_stoffa
Towie,
There is a little section of the owners manual that mentions something about 'when cleaning test on an inconspicuous part for fading , rusting or other adverse affects......... we was all warned , but as usual we didn't read the instructions ;)
ATC
Buy some CT-18 Truck Wash (Repco / Supercheap / auto stores etc...) and a cheap 5 litre pressure sprayer from Bunnings etc..
Mix to instructions and spray on & under.
Then just wash normally.
gets a lot of stuff dirt, grime etc...off a lot easier
frosty
Dont put CT-18 on your paint. Its called TRUCKWASH FOR A REASON. Use it underneath. Awesome stuff. I use it along with SHITLOADS of fresh water. Long term, truckwash will bugger your paint. Use carwash on the paint.
