Warn Winch
Maz_BT
Hi all
My warn winch won't winch in or out the free spool is fine, when I winch in or out nothing happens it just makes a clicking sound. The last time I used it was about 12 months ago.
Any help would be great cheers
I'll tag @Swaggie ,he kmows about warn winches.
Thanks mate..lol..What model is it just out of curiosity ??????? As a first guess it's the brushes are seized in there holders @ the motor end..Warn allow water into the motor area where they haven't bothered to protect the mild steel on the armature,brush holders etc..
Second guess would be solenoid..
Make sure your earths have a good contact
Cheers.
Maz_BT
Cheers.
Its a Warn XDC 9500LB fit in 2013
Chatty
I used to have a Warn 9,500lb and when this happened to me it was the solenoid(s). You might be able to clean it (them?) and get it working, but replacements are cheap enough on EvilBay.
Maz_BT
Thank you guys for your help my winch is working a again I cleaned the lugs on the battery terminal, the mob that serviced my car last sprayed some yellow shit on the battery terminals which ended up giving it a bad connection thanks again :):):):)
You should give it a run at least every couple of months even if you just wind it out the length of the remote and back in to keep things working.
rogerazz
Mine does not get worked much at all. It's just there , just in case.
But I do run it in and out at least once a month, to warm it up, dry out the dampness ( if any) and make sure it's working in case I need it.
