waeco cf 50 manual
The stink
I just picked up a 2nd hand cf 50 , its just had ceramic fuse problem fixed,
been round oz twice but i need to know what the emergancy ON / OFF &
LOW /MED/HIGH switches do . thanks
The Stink
kruzaman
Hi Stink, the emergency switch is used if something goes wrong with the control module and puts the fridge into limp mode and keep it working at set temp only that you cant change, the low/med/high switch is the low voltage cut out used mainly for single battery setups so you can still start your car. When set on low the fridge will work longer but the battery will not start your car.
Hope this helps
Lee
The stink
kruzaman
thanks for the info but it now looks like it has a few bugs,error light comes on when on 2nd battery with
engine off even though 2nd battery still has 12.5 v , noticed plug at fridge side hot so that means its
pulling lots of amps. and doing same with power supply , can hear compresser and fan struggling ,
have to look at plug and 2nd battery loom.
The Stink
croozza
kruzaman
The Stink
you may find that the previous owner droped it off the back of a ute or it has been under water at some stage, are you able to look at the electrics and see any damage.
The stink
Got all the bugs sorted with the fridge just need to get new rectifier.
Thanks everyone for the help.
The Stink
