(note : pdf attachment is attached)
For Sale: Waeco CDF-35 (CF-35) - $450
Waeco CDF35, with 240v inverter. Superb fridge can run direct from 12v or 240volt via included inverter, authentic Waeco
Uses German-made DANFOS compressor. Comes with Waeco insulation bag.
Fridge is in perfect working order, thermistor has just been replaced.
Background info: ALL Waecos use Thermistors for temp control, which over time does wear out. This CDF-35 has a brand new authentic replacement, so is in great condition for a 2nd hand unit. The DANFOSS compressors will last decades.
Only selling as I have purchased a larger Waeco unit.
-- Slight tear in the bag seam, not bad.
RRP: $699
Further stats ;
- Vertical space for 1.5 Litre bottles
- Super safe locking mechanism
- Easy to remove lid hinge
- Continuously variable electronic thermostat and battery monitor, with selector switch in 'Low' position.
Even in high ambient temperatures, the cooling is excellent and of course the freezing as well. Now comes in a pack including an EPS-816 240V AC Adaptor and a Protective Cover for the CDF-35.
Capacity: 31 litres (holds 37 cans)
Dimensions
W560 x H340 xD380 mm
Weight:
15 kg
Power Input
12/24V DC + 240V AC (AC Adapter included)
Consumption
Ave. Power Consumption: 45 watts
30% duty cycle at +32°C ambient temperature with
Temperature range:
Down to 45°C below ambient, temperature set via continuously variable thermostat
Insulation:
Full foam insulation in CFC-free polyurethane foam
System:
Compressor with integrated electronic controls, including low-voltage battery protection – adjustable using a slide switch, automatic reverse polarity protection, dynamically ventilated tube condenser, aluminium rollbond evaporator, heat dissipated by a brushless, long life fan
RRP: $699
Further stats ;
Dimensions
Weight:
15 kg
Power Input
Consumption
Temperature range:
Insulation:
System:
