volvo xc90 and sand
Superdad
Hi all
We are heading away with a group, one of whom has a Volvo XC90. The trip will involve a bit of beach driving....
Anyone know if this vehicle has any sand capability?
smitty_r51
Most sand work will be high range so an awd should be fine if you drop the pressures...i would be checking for recovery points as it is likely to be missing them (maybe a tow hitch point could be used...NOT THE TOWBALL)
Take a set of recovery boards too (maxtrax / treds) and a shovel
mikehzz
The 4wd system is in vw's, audi's and land rovers without low range. It's a front transfer case with a haldex at the rear. Each brand is tuned to respond to slip differently so I'm not sure how well the Volvo goes. The Land Rovers are full 4wd at start and gradually relax to front wheel drive only as the speed increases unless you lock in one of the traction programs. The Volvo doesn't have those programs. The biggest problem will probably be low profile tyres that you can't let down enough.
Superdad
thanks guys
clearance, tyres and lack of recovery points are the issue as far as i can see - i'll make sure old mate has a shovel....
#6
I towed one once on mt Hotham as he could not get it to drive on ice it kept sliding backwards into a bank
Only his front wheels would spin
He said it was all wheel drive
It towed him up to a flat spot and told him to call a tow truck lol
He couldn’t fit chains because his struts were to close to the tyres
Idn how he was allowed to take it up there in a blizzard lol if you ask me I wouldn’t trust there “all wheel drive” system lol
#11
The volvo system is very different to the system in vw-audi and porsche.
These are permanent full time 4wd with full even split torque distribution.
Where the Volvo is a predominant a front wheeler with little power going to the rear to correct front slippage.
So to answer your question, expect alot of recoveries and towing..
Superdad
So no centre diff lock?
mikehzz
I've got a pretty new Q3 Quattro and it has a Haldex awd system similar to the Volvos. All Haldex systems have a front wheel bias. Other Audis still have a Torsen system. The Haldex type can be pre charged up to give full all wheel drive from start up if they program it to. It does on my Land Rover as well but they mustn't have the Volvo do it going on the ice experience a few posts up.
#14
My only experience with Haldex system is when I get a loaner from Audi when mine is in for service.
It only comes online when certain preset parametres are reach, unlike the Q7, drives is always going through all for wheels. Similarly for the Amarok autos
