Vehicle Modification: Suspension Lift
Hi.
I am interested in putting a 6" tough dog suspension lift in my vehicle but before i do, i need to the legalities of doing it in NSW. I have spent roughly 6 hours researching this topic and cant seem to find any black and white answers. I have a 2006 Nissan Patrol GU IV ZD30 3L Turbo Diesel which is my work vehicle as well as what I use for offroading, so whatever i do to the vehicle needs to be legal. What i need to know is if a 6" suspension lift is legal on-road in NSW and if not, is there a way to make it legal? Also, what insurance companies will insure a vehicle with a 6" lift as i have contacted a few such as Allianz and AAMI and they said they will not insure a vehicle with over a 2" lift. The kit i am looking at getting is about $5,700 from 4WD1 and have no intentions on cheaping out on the vehicle.
Thanks in advance for any information you can provide.
Matt
muc the truck
Dont shoot the messenger but the sad answer is no. no one can certify it due to the new rules . Maybe club rego with restricted use but not standard rego
What are the current rules this week?
Is it 50mm suspension, tyres and body is ok without eng. report and a max of 100mm combined with eng. report?
Jarh73
I don't really think 4WD1 is the place for premium suspension products.
Like anything you could get it engineered but it could cost 1000's and 1000's of dollars.
A big lift in inherently less stable then a moderate lift and very few engineers are going to sign off on something that carries substantial risk. Put your self in the engineers position, he is not a genie he has to cover himself legally IF it goes wrong and you have an accident he may become liable.
Talking to the big insurance companies is a point less exercise, they DON'T like risk, you present a risk. You have to look at far more specialised insurance companies.
You might as well do what most people with big lifts just do it and take your chances.
Justin
Miraz
The current situation in NSW is that VSB-14 is a guide - it does not represent the limits of modifications that can be certified for on road use. If your engineer is happy with it, then you can still get full road rego.
There are a number of practical limitations on lift height that are in the ADR's:-
- The first one that most people hit is the positioning of the lights...the center of the headlight cannot be more than 120cm from the ground, so unless you are going to reposition them this will usually dictate the limit for your vehicle.
Some of the NSW certifiers are using the double lane change swerve test specified in VSB-14 to verify the dynamics of the modified suspension, although they have reduced the speed to 80km/h in accordance with the ISO standard referenced in VSB-14.
In order to pass the test you will need to have some combination of significantly uprated roll bars, raised roll centres and to have avoided very high profile tyres.
If you are going to buy a kit, then I would be asking the kit supplier if they have successfully put a vehicle through this sort of test already....or if they will provide some sort of warranty that it will pass.
There are vehicles with 6" lifts still getting through - my own vehicle running on 37" tyres, wheel base stretch, coil overs, etc went the process with no problem.
LowLux
Depends on how small your PEN 15 is as to how high you feel you need to go. Have to remember, you can only lift your diffs pumpkins up so high unless you start to put on much bigger rubber and the bigger you go, the bigger the $$$. I happen to have one of those 2", no terrain wearin trucks that 345 chippy is talkin about and I'll go anywhere I want it to with it. I've also pulled big lifted trucks out of bog holes. The question here is do you know how to drive your truck and is the 6" lift for a purpose or just pose. Good luck with it.
345 chippy
nothin 2 do with ya snag size here lowlux. 99.9999% of people have same idea with lifts etc.
99.99999% have never had or been in a big lifted truk and dont know their capabilities. yes u must put a larger tyre on. dont c 2 many truks running round in tuff tuks with 33's and 2" waste of $$$:D:D:D
soory...cant remember the last time i was pulled out legitimately by another truk. oh yeh, think it was when i only had 2" waste of $$$:D:D:D;);)
cheers chippy
345 chippy
come on now gold rush. how many times do u c small truks trying 2 drive the impossible.
im no fool and my snatch probably pulls out around 8 truks evry time i go out 2 tell the tale.
im no super hero but when they all get stuck, my undies go on the out side and up the truks go, SNATCHED 2 A MORE CAPABLE TRUK.
im proud of my truk and its capabilitys, it is pupouse built NOT 2 get stuk and ows me .....
not sure, lost count after the 6th suspension lift went in.
if i got stuk, i took it home and rebuilt it so i wouldn't get stuk again, and so on and on it went.
others get stuk just reverse down and try with more right foot.how is that right.
cause they r 2" lifted its allright. i go round them and they/you think im wreaking the joint.
come on get a grip. next thing i hear will b the banning of muddies cause they r 2 noisy in the burbs.
cheer up pple, there is life beyond a 2 inch lift
chippy
345 chippy
thanx m8, i also have a 4" lifted 35 wearin v8 hilux if u need some suspension advice 4 ya surf:D:D:D:D(engineered of course):D
chippy
Frankensurf
The old Surf still has the original 2.4 motor so I reckon she'd struggle to just turn a set of 35's :) Would also have to SAS it to get that much lift in the front. Sadly, the old girl just ain't worth spending that much money on.
V8 Hilux sounds cool :cool:
345 chippy
shes a good thing, and 4 sale. $4500 and shes urs. same price as GOOD rubber.
everything will bolt on 2 urs. mine started life as a 2.4.
smoke comes off all 4 35" muddies if that helps.:D:D
can post 2 u in bits:D:D:D:D
cheers chippy
PK Kitchens
Wow. I can't believe you acutely said that lift doesn't matter in the bush. So using that logic I can take diggers 4wd Subaru WRX down any track you can get your 4wd down. If lift has nothing at all to do with it. It's all about having 4 wheels I'm guessing.
People who don't like big trucks are just jealous they don't have one them self.
PK
PK Kitchens
I can't believe someone would make such a ridiculous comment. By taking comments to the extreme you are only proving your ignorance. You DON"T need 8" of lift to go 4wd'ing in the bush. You do need a reasonable amount of clearance but obviously some people just can't drive well enough to go off road without enough lift to drive over pine plantations without scraping their undercarriage. If you can't get there with a small lift and 33's it is not a track.
I can get more places than your lifted trucks in a dozer..... Does this mean I should take a D9 through all the tracks I can find and f@#$ them up for everyone?? .Dozers don't have huge lifts and they go anywhere. That would mean you don't need a lift at all. :eek::eek:
(Just using your logic that taking things to the extreme will make a valid point.)
Wow. You really think driving in pine plantations is 4wding. No wonder you think we don't need lifts.
PK
PK Kitchens
I know I'm just stirring up poo here but it's not fair to say big is wrong. Big has sooooooooo many more advantages that no lift can provide.
I'll make it up a track in one go with my 4" lift and 35" tyres with next to no wheel spin at all. If you tried the same track you would diff out for a start and maybe even dint a sill on the log we had to climb over. All the time spinning the shiz out of your wheel to find traction from the d9 pumpkin you have under your lowed toorak tractor.
We are talking about 4WDING here. Not touring the Kimberly. Or though a big lift could be handy in same spots up there too.
Now don't get all upset about it or start yelling and screaming on the ground like a 2 year who wants an 8" lift on he's tanka truck.
This is my option on the subject and that was my view to yours.
PK
Frankensurf
Thanks Chippy. But I don't think the missus will let me put another car in the yard at the moment. We've already got his & hers sedans; his & hers fourbys; the daughter's car; the daughter's fiance's courier van...
Although, if you did post it up in bits, I might just be able to sneak it past her... hmmmmm.... :D:D
PK Kitchens
The thing is that you are totally misrepresenting what I said. I have 3" of lift and 33's so if i can't get through the ruts then they have been made by 35's or bigger. I have yet to hear anyone argue against that point. You keep telling me how I will diff out on your tracks. That is only because they have been badly chopped out by bigger tyres. Have you ever considered the fact that there are other lines you can take on most tracks???? Honestly, you have a 4" lift and 35's.......You are NOT one of the big lifted trucks no matter how much you pretend to be.
Never said I was a big lifted truck. I still use my truck as a daily drive so I'm holding off on doing a bigger lift.
It's not bigger tyres making it un drivable for 33". That one comes down to Mother Nature. You got through with your 33s. Mother Nature sends 10'000 litres of water down the tracks and it washes an inch off of the top. There for you'll need 34s to clear then it all happens again. Until DSE send in the D9 to get rid of all of the ruts. We could all have 31s and we would all get stuff soon enough.
PK
